Price: $19.99 - $18.99
(as of Aug 07, 2024 09:00:13 UTC – Details)
10000mAh Emergency Radio
Emergency Weather Radio
Emergency Sleeping Bag
Esky Key Finder
Noise Cancelling Earmuffs
Air Pump for Inflatables
Wood Moisture Meter/Lux Meter
Luggage Scale
Fishing Scale
Soil Moisture Meter
Anti Lost Wrist Link
Life is full of uncertainties, emergencies and natural disasters like earthquake, hurricane, tornado, blizzard, or thunderstorm sometimes strike without any warning signs. What if we can be informed of these information before bad weather’s arrival?
The Esky emergency hand crank radio is designed with AM/FM & NOAA weather alert to keep you informed in advance, then you can make full preparation to reduce the loss and damages.
3 Charging Modes: No electricity? No worries. Thanks to its 3 charging methods, the emergency hand crank radio is always ready to go! The powerful 2000mAh battery can be charged via a USB cable, the solar panel, or the hand crank
2000mah Power Bank: A dead phone can be life- threatening. Don’t let your phone die when you need it most! Simply plug your phone or other small electronics into the USB port of this 2000mAh emergency power bank for some extra juice
A Survival Tool: Hurricanes, tornadoes, rainstorms, fires, and more–the Esky emergency alert radio will be a great survival gear and supply. It’s a weather radio, power bank, emergency flashlight and SOS alarm emergency kit
Ultra Bright Light: Don’t let the dark get you down. The 140 lumen built-in 3-LED emergency flash light will cut through the darkness and maximize visibility
Portable & Lightweight: This lightweight AM/FM/NOAA solar crank radio is a hassle-free way to listen to important weather or news updates. Keep the portable radio in your trunk, your suitcase, or carry it by hand with the attached lanyard. The emergency radio is even small enough to fit in your pocket
