eRapta HD 1080P 10″ Wireless Backup Camera System 10-inch for RV Truck Trailer Van Quad Split Monitor with Recording, IP69 Waterproof Rear View Side View Cameras, Digital Signal Parking Lines AWX103
Price: $359.99
(as of Sep 02, 2024 10:00:26 UTC – Details)
wireless backup camera with 10 inch monitorwireless backup camera with 10 inch monitor
Loop recordingLoop recording
1080P1080P
360° blind-free zone360° blind-free zone
Loop recording
Loop recording and local playback make it be the dash camera. Equipped with a 32GB SD card to help you save all your data.
HD image
The reversing camera can accurately acquire a crystal image even in low light conditions.High pixel image resolution effectively reproduces the color of the surrounding environment.
Four-channel monitor with two side view cameras and two rear view cameras, the most complete combination to provide you with a 360° blind spot-free security
IP69KIP69K
Superior Night VisionSuperior Night Vision
Dlignment gridDlignment grid
IP69K
The unique exterior design effectively blocks rain and fog from entering the lens. Even in extreme weather, it can perform well. Use it with confidence!
The reversing camera can accurately acquire a crystal image even in low light conditions, which makes it safer to drive at night.
Alignment grid
Clear and precise reverse lines switch on and off at any time according to your preference.
backup camerabackup camera
10 inch monitor with HD image: With the dimension of 9.88×6.46, the large 10 inch screen provides us more details, avoiding the blind spots. Featuring 1080P higher resolution, it produces vivid, colorful and clear image in real time without any distortion.
Stable&Strong wireless signal: Adopted advanced digital technology, the system can transmit the signal in real time even in a farther distance of 135ft range. The transmission speed up to 102mp is daringly quick and stable without any delay and interference. The great wireless signal allows our driving journey more safer and happier.
Looping recording&alternative screen: Pre-installed SD card inside, the system can store what it records. It supports playback when you need look back the videos. The system automatically deletes the old contents saved when the SD card is full, which provides us more convenience to use it. The camera channels are alternative, allowing you add up to 4 cameras and choose the full screen or split screen.
IP69 Waterproof &great night vision: The hard mental housing ensures the camera perform well and durable whether it is rainy or cleaning. 10 infrared lights give us a clear night vision in the dark, whose lens are adjustable to view in different angles.
Easy installation: Just need to power the camera by the power cable, and mount the monitor by the car charger or hard wire . Easy installation helps us save much time!
