eRapta Backup Camera for Truck 7”HD 2K Front Rear View Monitor kit IP69 Waterproof Night Vision DIY Grid Lines for Car RVs Trucks Tractors Bus Semi-Trailers Pickup AY7
Price: $49.99
(as of Aug 19, 2024 11:30:24 UTC – Details)
Wired 7" Camera SystemWired 7" Camera System
2k Vivid Image IP69K Waterproof Parking Safety/ 149° View DIY Guidelines 1 2K Iamge 2 IP69 Waterproof 3 Parking Safety 4 DIY Guidelines
Excellent Night Vision Upgraded Technology Wide Compatibility 1 Excellent Night Vision 2 Upgraded Technology 3 Wide Compatibility
Easy Installation Two Power Supplies Dimensions Package Listing 1 Easy Installation 2 Power Supply 3 Dimensions 4 Package Listing
eRapta Wireless Backup Camera System
2 Minutes Easy Install
Megnetic wireless backup camera, plug and play.
3 Minutes Easy Install
Truthly wireless backup camera, magnetic camera monitor plug and play.
10 Minutes Easy Install
A simple plug and play method for pre-prepared RVs.
Powerful Magnetic Camera
The camera can be attached to any metal surface without wiring.
Powerful Solar Magnetic Camera
Solar panels & Rechargeabl battery, stable signal, quick & portable Installation
Loop Recording
Loop recording, auto-delete and playback enhance security.
9600 mAh Battery
Breaking the capacity limit, ultra-long life.
3500 mAh Battery
3500mAh large-capacity battery and equipped with a solar panel.
4 Cameras extension
System can be easily expanded to 4 cameras.
Specifications of eRapta AY7 Wired Camera System
Effective Pixels 2K Waterproof Rating IP69K Material Metal Item Weight 2.05 Pounds Power Supply DC 12-24V Working Current 400 mA Standard Format PAL Mounting Type Bracket Mounting Extension cable 4 Pin Connector/ 32.8 ft
2K Clear Iamge: 7” High Resolution monitor with built-in CMOS upgrade chip provides vivid images. Designed for Car, Pickup Truck, SUV, RVs, Minivan, Sedans etc.
Easy Installation: Camera system is powered by car charger – a simple plug and play. The screen is mounted on the windshield or desktop for easy viewing, and camera can be hidden under the license plate.
Night Vision Camera: 9 LED lights of the upgraded reversing camera automatically light up at night, equipped with 6 glass lens, continuously provide high-definition images to ensure night-time driving safety.
IP69K Waterproof: The camera housing is made of high-density impermeable material with efficient dustproof, shockproof and waterproof performance to ensure the camera longevity and durability.
Powerful System: Used as a front or rear camera, camera equipped with DIY reversing line and mir-flip function. Also with adjustable brightness, contrast, saturation, tint and language for a perfect viewing experience.
Safety Assurance: Support for up and down angle adjustment and 149° wide viewing angle design ensure safe driving and blind spot-free parking.
What You Get: 1 x Monitor, 1 x Camera, 1 x 33ft Power Cable, 1 x Car Charger, 2 x Brackets, 1 x Remote Control, Two Year Warranty and Lifetime Technical Support. eRapta support department will always be there for any consultation.
