EnginStar Portable Power Station, 150W 155Wh Power Bank with 110V AC Outlet, 6 Outputs External Battery Pack Portable Backup Battery Laptop Charger with LED Light for Home Camping
Price: $149.99 - $119.99
(as of Aug 17, 2024 15:45:29 UTC – Details)
EnginstarEnginstar
CapacityCapacity
charging waycharging way
FAQ:
Q1: How to know the working times for my device?
A1: Working time = 155Wh* 0.85 / operating power of your device
For your information, if the power consumption of your device was 30W, The running time will be 155Wh*0.85/30W=4.4hrs (rough calculated).
Q2: What equipment can be powered by the unit?
A2: Please note that the AC output port can only charge devices that operate at less than a total of 150 Watt. Recommend to charge the laptop by using the ac adapter
Note: Need to recharge this unit in time after drain all the power.
Recommend Fully charged every 3 months to keep the power station in the best working condition and store it between -20 and 45 °C.
Keep your portable power station away from heat and direct sunlight in order to extend its life span.
forbidenforbiden
safetysafety
camping power stationcamping power station
Devices which is over 150W not Supported
BlenderElectric GrillInduction CookerMicrowaveRefrigeratorCoffee Maker
Kindly check the rated power of your electronics before using this 150W portable power station.
Advanced Protection System
Advanced battery management system and multiple safe-charging design can protect the product from the damage of short circuit, overcharging and overload, to make sure you use it efficiently and safely.
LED Light For Emergency
Bright light with 3 modes like steady light, strobe, S0S for help
It is applied to outdoor activities such as van life, camping, hiking, outdoor photography, fishing, and short power outage.
SPECIFICATIONS
Capacity 155Wh (42000mAh) Battery Lithium-ion Battery AC Output 150W/110V/60HZ DC Output 9-12.6V/10A max USB Output 5V/3.1A USB-C Output 5V/3A, 9V/2A, 18W Max Weight 4 lbs Dimensions 7.5 x 4.5 x 6.5 inches Solar Panel Supported DC 13V – 23V (solar panel not included) Charging Input 15V/2.4A (About 5 hours to fully recharge)
4.3 out of 5 stars
901
4.5 out of 5 stars
35
4.7 out of 5 stars
4
2.0 out of 5 stars
1
11
5.0 out of 5 stars
2
$119.99$119.99 $168.99$168.99 $186.99$186.99 $114.99$114.99 $175.99$175.99 $203.99$203.99
Battery Capacity
155Wh/ 42000mah 155Wh/ 42000mah 155Wh/ 42000mah 155Wh/ 42000mah 155Wh/ 42000mah 155Wh/ 42000mah
AC Output
150W Max 150W Max 150W Max 150W Max 150W Max 150W Max
USB-A Output
2* USB 5V 3.1A max 2* USB 5V 3.1A max 2* USB 5V 3.1A max 2* USB 5V 3.1A max 2* USB 5V 3.1A max 2* USB 5V 3.1A max
USB-C Output
1* USB-C: 5V/3A, 9V/2A 1* USB-C: 5V/3A, 9V/2A 1* USB-C: 5V/3A, 9V/2A 1* USB-C: 5V/3A, 9V/2A 1* USB-C: 5V/3A, 9V/2A 1* USB-C: 5V/3A, 9V/2A
Power Bank DC Output
12V/8A 12V/8A 12V/8A 12V/8A 12V/8A 12V/8A
Solar Panel DC Output
/ DC Output 40W Max DC Output 60W Max / DC Output 40W Max DC Output 60W Max
Portable Power Station: EnginStar 150w power bank, equipped with a 155Wh lithium battery pack, no fuel or gasoline needed, much quieter than gas powered generators, Only 4 lbs, the size is only 4.5*6.5*7.5 inch, easy to carry the external battery station for your next camp trip, hiking or exploring nature
Multiple Charging Ports: 1* 110V/150W AC outlet, 2* DC outputs(9V-12.6V/10A), 2* USB ports (5V/3.1A max), 1* USB C port(5V/3A, 9V/2A). Enginstar portable power station with 6 outputs run simultaneously can provide stable power 155Wh, to power your small electronics device like phone, mac book, fan, tablet, camera, drone, laptop, lights and more
Advanced Clean Power Supply: 42000 mah power bank, built in li battery pack, power clean energy to protect environment and power your electric device, with easy to read LCD screen for AC, DC input and output, LED light on the back with 3 modes: steady, strobes, SOS, it is convenient for indoor blackout, or outdoor camping emergency
Superior Protection System: EnginStar 110v power bank passed UL certification, with fireproof enclosure, built-in over-voltage, over-temperature, short circuit, overcharging, and overload protection to protect your device safe, over 1000 time recharge time, longer battery span
3 Charging Ways Power Supply: battery powered charger can be charged via being plugged into wall outlet at home; solar power generator can be charged with any compatible 13- 23V solar panel(optional) at sunny outside in field; The portable generator can be charged via being plugged into wall outlet; The battery powered power station can be charged from 12V socket by the car
Tips for protecting battery station: 1. Fully charge the electricity power station before using 2. If it is not used for a long time, the stored battery should be recharged every 3-6 months, and it is appropriate to keep it at 40%-70%. Recharging the battery before it is completely exhausted 3. The battery should be stored in a dry environment at 40°F~100°F (4°C~35°C) or in moisture-proof packaging. Keep away from heat sources, and don’t place it in direct sunlight
Note: 1. This 150w solar generator only support lower than 150Watt Hour device, it may not support large capacity product(Electric Grill/ Induction cooker/ Microwave/ Refrigerator) and more 2. It is normal when you turn on the ac output button, the red triangle shows up for checking AC output and will disappear in 3-5 seconds
