Price: $36.99
(as of Sep 23, 2024 10:00:21 UTC – Details)
NIP IN THE BUD
An 8 in 1 life saving escape tool can protect you from sudden emergencies
* USB Pow banker * Safty Hammer * LED Flashlight * Strobe Light
* Seat Belt Cutter * Siren Alarm * Magnet * Hand Cranking Charging
8 in 1 Car Emergency Tool
Safty Hammer
Safety hammer with protective covering, also known as window breaker, is made of high-strength material. The hard tip with good corrosion resistance and high hardness makes it easier to break the window.
Escape tips: Tap the four corners of the side window, the smaller the corners, the less laborious.
Seat Belt Cutter
Embedded blade will not cut people or objects, and when you are in danger, you can quickly cut off the seat belt and help you escape as quickly as possible.
Emergency SOS light & Siren Alarm
Red Strobe Light (SOS lighting) with 100db lound siren alarm, loud sound which can reach clear warning effect. Easy to ask for help and easier to be found in outdoors where there is dark.Let’s get the rescue quickly.
Magnet
With 4 magnets on the top flashlight, it has strong suction and can be attached on the vehicle body. Also it can be used as the signal mark cooperate with the SOS emergency light.
LED Flashlight
High-brightness LED lights, with low energy consumption, long-lasting etc, can be used as a flashlight when the car fails, or when there is a power outage in life.
USB Powerbank
USB current output, not only can help charge the phone, but also give a variety of electrical interfaces USB charging. Meet emergency power, communications and other demands.
Hand-cranked power can still normally be used when there is no electricity, 1 minutes flashlight held for 15 minutes, three minutes can charge available 3-8 minutes of talking time of the phone.
Compact Design
An escape tool with only 9.68*3.3 inches (the size just like a vacuum cup) &9.17 oz which has powerful features and is versatile. Life is only once time chance, you need it very much for the safety of you and your family.
4.7 out of 5 stars
12
4.8 out of 5 stars
9
$36.99$36.99 $35.99$35.99
Color
Blue Orange
Hand Cranking Charge
Magnetic
Type-C Charge
Window Breaker
Seat Belt Cutter
◈8 in 1 EMERGENCY KIT: We wouldn’t predict when an accident will be happen,So we need multifuctional safety hammer to keep ourselves and our lover safe in an emergency situation.The multifunctional emergency tool with Car safety hammer, Seat belt cutter,Siren Alarm,Strobe Light (SOS),Magnet, LED flashlight,USB charger with cables,Hand cranking charging system.
◈WINDOW BREAKER & SEAT BELT CUTTER: The automotive safety hammer as an emergency escape tool can break the windows, and the seat belt cutter with sharp razor blade can cut off the seat belts. Allowing you to escape quickly from your vehicle in an emergency situation.
◈HAND CRANKING CHARGING SYSTEM: The emergency tool with USB charger and USB cable has a special skill to save itself, that is hand power generation. As well as, it can charging for most phones in an emergency circumstance.
◈LIGHTING TOOL & EMERGENCY SOS & SIREN ALARM: Bright light and SOS light are the most important in an emergency situation,We can use the car emergency kit with LED light as a flashlight.The SOS light will flashing after turn on switch and long click the swith,The siren will sound loudly meanwhile the SOS light will flashing enough to catch the attention of others when we are in the dark or emergency or need help,let’s get the rescue quickly.
◈MANETIC FLASHLIGHT:The top of flashlight built-in powerful magnet,You can stick directly on the car lid or any ironwork as a warning light or repair light when your car break down, free your hands.
◈APPLICATION AND 1 YEAR WARRANTY: The best gift for your loved one who likes camping, wildlife adventure,field survival, hiking, travel exploring, camping, fishing or backpacking,This car escape kit comes with a 1 year hassle-free warranty, if you have any issues with your order, please contact us directly, we’ll respond within 24 hours to give you a satisfactory reply.
