Emergency Radio,5000 Hand Crank Solar NOAA Weather Radio,AM/FM Portable Battery Operated Radio with 5-Way Power,Phone Charger,Flashlight&Reading Lamp,Earbud Jack,Compass,SOS Alert for Home,Survival
Price: $39.99 - $35.99
(as of Jul 22, 2024 21:30:15 UTC – Details)
radioradio
radioradio
radioradio
radioradio
radioradio
ROCAM is a company that focuses on providing customers with quality emergency radios.
-In recent years severe weather, and various temporary power outages in homes have occurred frequently. We are eager to provide you with unlimited convenience when special circumstances arise. Don’t hesitate to choose our weather radio to solve your emergency needs!
【AM/FM/Shortwave Radio & NOAA Weather Alert 】- This portable radio has a wide range of band reception of AM, FM, Shortwave and NOAA weather stations with the extended telescopic antenna. Shortwave Radio allows you to receive some weird stations from other locations. There are also 7 weather channels are pre-programmed so you can easily tune into your local one, you will hear a Loud Alarm Sound from the NOAA weather signals if there is a severe weather hazard in your area such as storm, hurricane
【5 Power Sources & Rechargeable Battery】 -This weather radio supports 5 way to keep device powered. It comes with the upgraded rechargeable battery to charge your cell phone, tablets or other devices. In case the rechargeable battery is power off, the solar panel and the crank lever can keep your radio connected and powered. You can install 3 AAA batteries into the compartment when you are not able to regenerate power, also you can just simply plug the radio in wall with DC adapter.
【2 Bright Light Sources & Compass】 – Light is important when you are in the dark, this crank radio comes with 3W flashlight and a 6 LED reading lamp, which are brighter than other radios in the market, with easy to reach switch button at the right side, user-friendly design to adjusts the reading lamp to the front, making it easy for users to set and adjust the radio when they are outdoors. The campass attached on the carry strap can guide you to the correct directions when you lose your way.
【Loud SOS Alarm Flashing Red Light & 3.5mm Headphone Jack】 – Simply press the SOS button for asking for help in case you are in danger or you would like to warn someone else, the SOS alert sound is extremely loud and can be heard miles away. There will be a flashing red light on in the meantime; The earphone jack on the right side of the radio allow you to enjoy the your favorite audio more clearly.
【Easy to Carry & 12 Months Replacement Warranty 】- The size for this weather radio is just7.5*3.5*4.7 inch with 1.2LB weight, and we have included a carry strap and a hang buckle so you can take it anywhere you want, this emergency radio is made of strong ABS material which is IPX6 water resistance. A necessary tool for camping, traveling, backpacking or any other outdoor activities. A ideal gift option for adventurers. – We provide our customers with 12-Months Warranty.
