Emergency Radio Hand Crank Solar,Portable Weather Radio with AM/FM/SW/NOAA,Bright Flashlight,SOS Alarm,Reading Lamp,2000mAh Cell Phone Charger for Survival Camping Home Outdoor
Price: $27.99
(as of Sep 17, 2024 04:30:17 UTC – Details)
0101
Emergency Weather Radio Portable Hand Crank with FM/SM/WB/SW,Bright Flashlight,Alarm,Reading Lamp,Headphone Jack for Emergency,Hurricane
Emergency Weather Radio: Full band high sensitivity radio supports FM/AM/SW radio, retractable antenna for better signal. The built-in 2000mAh can charge mobile phones and other digital products in an emergency. Can be used in emergencies and storms to light up dark spaces and areas, or to keep your room bright and bright for life after a power outage.
Function:
1.Recharge:Hand-crank charging/USB charging/solar power supply
2. Radio Mode:FM/AM/WB Radio Receiver
3. Output Current: Emergency Charger (for Mobile Phones)
4. Flashlight: LED Lamp & Reading Lamp
5. Alarm: SOS Alarm
6.2000mAh Charger
0202
0303
1212
Flashlight & Reading Lamp
The emergency weather radio has two lighting methods, a flashlight with a maximum distance of 35M and a reading light, which can be used at the same time. The use time can be up to 30 days. Suitable for any emergency.
FM / AM / NOAA Radio
Multi-band radio, full-band high-sensitivity radio supports FM/AM/SW radio, can stretch the antenna to get better signal.
2000 Large Capacity Phone Charger
Emergency radio with 2000mah phone charger can ensure that you and your family’s mobile phones have sufficient power in an emergency, and it is suitable for most mobile phones,and it can be fully charged in about 3h.
0505
0606
0606
SOS Emergency Alert
In case of disaster or emergency, you can use the alarm to call for help, press the SOS button to sound a loud siren. Press the SOS button again to turn it off.
Stereo Headphone Jack
The solar radio can be connected to 3.5mm earphones, so that you can listen to music without disturbing others.
Portable Hand Strap Radio
This portable radio is small and lightweight, making it easy to carry around.Allows you carry this portable emergency raio for camping, hiking and other activit.
1010
Specification:
Type of radio/recorder: radio
Channel selection: manual, automatic
Sound quality selection: Stereo
Function: USB interface, built-in speaker
Signal-to-noise ratio: ≥75dB (dB)
Rated voltage: 5 (V)
Rated power: 3 (W)
Material: ABS
Dimensions: 147*76*57mm
Weight: 350g
Battery Specifications: 2000mAh
Charging Duration: About 3 hours
Packing list 1* Emergency Weather Radio 1* Handy Braid belt 1* USB cable 1* Manual
0808
3 Power Modes:
You can also choose solar power, hand crank charging for this crank radio, charging with micro USB cable. It can be charged on sunny days even in the dark without electricity, and hand crank charging is always safe at full power.
0909
Emergency Weather Radio: Full-band high-sensitivity radio supports FM/AM/SW radio, stretchable antenna for better signal. Can be used in emergency situations and after a storm cuts your power, to illuminate dark spaces and areas or to let Keep your room bright and bright for living.
2000mAh and LED Flashlight: In case of emergency power outage, this emergency radio can last your mobile phone, provide your family with ample emergency power, and make important calls or contact rescue in emergency.
3 Power Modes: You can also choose solar power, hand crank charging for this crank radio, charging with micro USB cable. It can be charged on sunny days even in the dark without electricity, and hand crank charging is always safe at full power.
Emergency Radio and SOS Alert: The Alert Radio provides life-saving information when a hurricane, tornado, earthquake, flood, or other emergency is likely, and it also includes a USB connector for charging USB-enabled smart devices for communication. Just press the SOS button that triggers a loud alarm, combined with a prominent flashing red light to get emergency assistance.
Portable Radio and Headphone Jack: This portable radio is small and lightweight, making it easy to carry around. Includes a 3.5mm headphone jack, allowing you to listen to the weather radio at night without disturbing your travel companions.
