Emergency Radio Hand Crank Solar, Wind Up Solar Radio Flashlight Cell Phone Charger 2000mAh Battery Portable AM/FM/NOAA Weather Radio SOS Alarm for Camping Hurricane Earthquake Home &Outdoor Emergency
Price: $32.99
(as of Sep 07, 2024 20:00:16 UTC – Details)
Emergency Radio Hand Crank SolarEmergency Radio Hand Crank Solar
hand crank radiohand crank radio
ABOUT WARLOVPO
WARLOVPO is relentless in pursuing the latest technology of products and in providing the best possible user experience. We design, develop, manufacture, and promote our own products to assure customers of reliable, cost-effective but high-quality products possible.
OUR MISSION
At WARLOVPO, we believe that true innovation is all about changing, renewing or creating more effective products that make life simpler.
hurricane radiohurricane radio
noaa emergency weather radionoaa emergency weather radio
noaa weather radionoaa weather radio
❤【2000 mAh Rechargeable Battery keep devices powered】WARLOVPO wind up solar radio incorporates a 2000 mAh built-in large battery capable of providing emergency power to any small tablet or cell phone. The emergency radio is a valuable and necessary emergency kit for home & outdoor use in different application scenes.
❤【3 power way charged when you need it】In the event of power cuts, long trips, or even hiking and camping when you need backups for charging or light. The hand crank radio has 3 power sources: Hand crack charger, Solar panel powered, Type-C USB interface. The solar power emergency radio’s crank lever and solar panel are both capable of regenerating enough power to keep the radio, lights, and SOS alarm ready to go when you need it most.
❤【NOAA emergency weather broadcast access】The NOAA Emergency Weather Radio Could connect to local weather broadcasts and AM or FM stations. Either NOAA radio gives you dependable access to emergency NOAA weather broadcasts. Help you and your family live through the hurricane tornado weather and snowstorm season. The portable radio is might be your life saver in an emergency.
❤【Bright Sound SOS Alarm & Hand Crank Flashlight】With WARLOVPO Emergency Hand Crank Radio you could press SOS mode sound loud when you separated from a group or in an emergency case you can emit a loud siren to protect youself or seek help. The emergency weather radio’s 3 power sources ensure you have the power to alarm the SOS sound and give a necessary emergency call. With bright crank emergency lamp, when you are out in the woods in the dark, a simple bright light is really all you need.
❤【Portable & Lightweight 】We CARE about you and your loved ones! Our portable weather radio is small, very easy to carry or pack. Portable radios with best reception. Quite necessary and valuable to have this in the emergency box. Packing List: 1 X Solar Hand Crank Radio, 1X Type-C USB Cable, 1 X Lanyard, 1 X Owner’s Manual.
