Price: $20.90
(as of Aug 10, 2024 17:45:10 UTC – Details)
Empower your adventures
Rychi creates value for users by providing emergency radios that can be charged via hand-crank, solar power, or USB.
These radios feature AM/FM, shortwave, and weather band channels and are made with high-quality materials and advanced production technology to ensure stable performance in harsh conditions.
Rychi is a trusted choice for those seeking reliable and versatile outdoor equipment.
Emergency Crank Radio
Emergency Crank Radio with LED Flashlight for Emergency, Portable AM/FM NOAA Weather Radio with 2000mAh Power Bank Phone Charger
Hand Crank
This function allows the radio to operate without batteries or external power, making it essential for staying connected in a crisis.
Solar Panel
Solar panel provides emergency radio with alternative power source and flexible, essential for crisis situations.
Micro USB Charge
Micro USB charging feature allows emergency radio to be charged by portable power banks, convenient for on-the-go power supply.
✬【NOAA WEATHER RADIO】This emergency weather radio has extensive reception for AM, FM and 7 NOAA weather channels with a retractable antenna.NOAA keeps you up to date on tornadoes, hurricanes, winter storms, earthquakes, wildfires and other severe weather conditions, alerting you to prepare in advance to keep you and your family safe. Whether indoors or out, it’s the best choice for emergency weather situations.
✬【2000mAh EMERGENCY POWER】When we get into trouble in an emergency, an emergency radio with 2000mAh emergency power may be a life-saving tool for us. This AM FM radio can be used with most USB-powered devices to provide enough emergency power to your device, giving you the opportunity to get the latest information or seek help from relevant agencies and departments.
✬【3-WAY POWER SOURCES】This NOAA weather radio can be powered by Type-C charging, hand cranking or solar panels. In general, the Type-C port allows you to quickly charge your emergency radio. If you run out of power while hiking or downhill camping, the solar panel and crank handle will keep it connected and powered, and 1 minute hand crank will provide up to 18 minutes of light or 6 minutes of radio.
✬【PERFECT FOR EMERGENCY AID】This emergency weather radio measures 5*1.8*2.4 inches and weighs 0.5 LB, making it lightweight and easy to carry. The portable radio also comes with a bright LED flashlight that can light the way under your feet in the dark.The multifunctional radio will be the perfect assistant for all emergencies.
✬【USER-FRIENDLY TECHNICAL SUPPORT】Your voice drives us to do better. The wrist strap design makes this pocket-sized radio easy to carry. We back this portable AM FM radio with an 18-month warranty and lifetime technical support. If you’re not satisfied with this NOAA weather radio, please contact us and we will get back to you with a solution as soon as possible. And our customer service is here for you 24/7 for anything you need !
