Price: $48.00 - $36.99
(as of Sep 01, 2024 23:00:32 UTC – Details)
Eight exhaust holes, heat circulation
There are eight vent holes on the edge of the food box to promote the all-round heating of water vapor, so that the airflow in the lunch box is unobstructed, the food is heated evenly and quickly, and at the same time, it releases the maximum flavor and nutrition
Made of TOP GRADE stainless steel
More corrosion resistance, impact resistance
Easy to clean and can be used for a long time.
SPECIFICATION:
Name: Electric lunch box
Material: Stainless steel + Food-grade Polypropylene(PP)
Capacity: 2L
Size:23 x 18cm
Layer number: 3 layer
Rated voltage: 110V
Rated power: 200W
Package Included:
Portable lunch box
2L bowls(1.0L+0.7L+0.3L)
Measuring cup
Power line
Manual
Let’s take a look at the menu of electric lunch boxes
1. Cook rice and heat up food.Cook egg custard or boil eggs.
2. Cook porridge. Such as preserved egg and lean meat porridge, mushroom chicken
3. Steam dumplings, steamed buns, buns, corn, sweet potatoes and other coarse grains
4. Soup. Rib soup, chicken soup, mutton soup, fish soup, etc.
5. Boil Syrup. Papaya Tremella Syrup, Lotus Seed Lily Tremella Soup
How to use electric lunch box?
1.Pour an appropriate amount of water into the heating base. Pour rice and water into a bowl
2.install the steamer rack,and put the food. (Note: The lid of the inner tank does not need to be covered)
3. Plug in the power and turn on the switch
You can use the same method to make other delicious meals
How to maintain this heated lunch box?
1. After use, please unplug the power plug from the power socket in time.
2. The upper cover of the outer box, the sub-lunch box and the steaming rack accessories can be cleaned with detergent and sponge. Do not use hard steel wire for cleaning to avoid damage to the surface.
3. When there is dirt on the periphery of the body, please wipe it with a wet towel. Do not wash the body in water to avoid electric leakage and malfunction.
4. If the lunch box is not used for a long time, please clean it, put it in the packing box.And put it in a ventilated and dry place to avoid moisture and influence the use.
Unique steaming rack, independent heating
Vent holes – steam evenly heats up quickly
Fixed steaming rack – safer to steam hot food
Egg tray – comes with egg steaming rack for easy operation.
Lunch box handle
Invisible handle design. Small and easy to carry, comfortable
PTC heating base
When there is water shortage, it will automatically power off protection
Double buckle
Adopt buckle connection, convenient operation, long-term reliable using
Switch
The operation is convenient and simple. One-click start. Safe and secure
MOBILE “KITCHEN”
Outdoor
Outdoor travel, spring outing, easy to carry. You can cook it yourself and give it to your lover. Experience the sweetness and warmth.
School
Balanced nutrition. Prepare healthy meals for children and refuse to take out. Let the children be in a good mood every day and achieve great results.
Working
Full of energy and high efficiency. It is too troublesome to go home for dinner at noon. The portable lunch box helps you solve all problems. You can also carry it when you go out to work.
4.0 out of 5 stars
752
4.0 out of 5 stars
752
4.0 out of 5 stars
752
4.0 out of 5 stars
752
4.0 out of 5 stars
752
$36.99$36.99
$35.99$35.99
Capacity
2L
1.3L
2L
1L
1.2L
Layer
2 Tiers
1 Tier
2 Tiers
2 Tiers
2 Tiers
【High quality】Electric lunch heater is made of food grade high temperature resistant PP environmental protection material, no peculiar smell, healthy and sanitary. The stainless steel inner bowls transfers heat quickly. Easy to clean
【Protection functions】Automatic power-off protection,when there is no water in the base, it will automatic power off, more secure.Double silicone ring,sealing and retain freshness
【Easy to carry】 Ultra-thin and comfortable hidden handle design, including the inner tank, removes the interlayer between the body and the inner tank.Reduce the weight, and allow you to easily control
【A mobile kitchen】The electric lunch box has dual functions of heating and keeping warm. It is convenient to cook meals, vegetables, soup and other food. A good helper for home, outdoor,work, camping
【Packing included】The portable heated electric lunch box set is designed for food cooking, steaming and warm keeping. Including 1 x lunch box,3 x bowls,2 x lids,1x measuring cup,1x power cord
