Electric Lunch Box Food Heater, Yokgrass 2-Compartment Fast Heating Adults Food Warmer for Car Truck and Home, Protable, Leak Proof, with 1.5L Stainless Steel Container, Fork, Spoon and Insulation Bag
Price: $25.99
(as of Aug 28, 2024 09:15:35 UTC – Details)
yokgrass electric food warmeryokgrass electric food warmer
Our portable electric lunch box will bring convenience to your life, allowing you to enjoy a clean, hygienic and delicious hot lunch.
electric lunch boxelectric lunch box
55W electric lunch box55W electric lunch box
protable food warmerprotable food warmer
Insulation BagInsulation Bag
Fast Heating
Our lunch box can help you warm food faster than other lunch box, Using fast ptc heating technology to keep food at a suitable temperature and keep the moisture of the food.
Leak Proofing
With the leak-proof seal ring design,pevent fluid leakage in sloshing car environments.
Easy to Clean & Dishwasher Safe
The stainless steel container is removable and dishwasher safe.
Insulation Bag
This Lunch Tote is light-weight and foldable, Sturdy and durable, easy to carry. Insulated aluminum foil makes the food fresh for hours,it’s non-toxic and safe for your food.
【3 IN 1 ELECTRIC LUNCH BOX】 Electric heating lunch box contains two different plugs: one for Work/Home (110V), one for Car/Truck (12v/24v). People who on the road for lunch or without access to a microwave, such as truck/Uber driver/office worker will be able to enjoy hot homemade food in the car/office.
【SAFTY & FAST PTC HEATING TECHNOLOGY】Using PTC original constant temperature heating, low-consumption heat cycle to keep food at a suitable temperature and keep the moisture of the food. It normally takes 20-30 minutes to warm the food, super efficient and energy-saving. (If the food was taken out of the fridge or where the ambient temperature is low, the heating time should be extended appropriately).
【COMPARTMENT DESIGN】Yokgrass electric heating lunch box has a 2-compartment design for separating your favorite foods, such as stew, lasagna, meatballs, mac & cheese, home-cooked meals, heated lunch box.
【LEAK PROOFING】Improved cover design, the cover will not move during use, more tightly covered. Because leak-proof seal ring design is added, it improves the defect of food leakage. Prevent fluid leakage in sloshing car environments.
【MATERIAL & HEATING NOTES】The electric lunch box is made of food grade PP plastic and stainless steel, which is high-temperature resistant, non-toxic, durable, eco-friendly and safe to use. Warm Tips: Please do not clean the heating base with water, and do not add water to the heating base.
