Electric Lunch Box Food Heater, 110V 12V 24V, Food Warmer for Office, Truck, Car, Work, With Removable Stainless Steel Container, Loncheras Electricas Para Calentar Almuerzo
Price: $17.65
(as of Aug 23, 2024 13:45:39 UTC – Details)
Electric Lunch BoxElectric Lunch Box
Easy To Use & Clean
Our Electric Lunch Box makes it easy to heat up your food in minutes, no matter where you are. And with our removable stainless steel container, cleaning and storage is a breeze.
rr
ww
zz
cc
Filligs Electric Lunch Box: The Ultimate Solution for Hot Meals Anytime, Anywhere!
Are you tired of having to settle for cold, bland lunches when you’re on the go? Do you want to enjoy hot and delicious meals anywhere, whether you’re at work, Office, or on a road trip? Look no further than our Electric Lunch Box Food Warmer!
✅【Your Portable Kitchen for Hot Meals on-the-go!】The electric lunch box is designed to be portable and convenient for meals on the go. The food heater lunch box is compact and has a handle, making it easy to transport. Additionally, they are equipped with a power cord plugged into an electrical outlet or USB port, allowing users to heat their food anytime, anywhere.
✅【DURABLE & LEAK-PROOF LUNCH BOX】Filligs heated lunch box are made from high-quality materials that are durable, long-lasting, and leakproof. The containers are made of food-grade plastic or stainless steel, easy to clean, and resistant to stains and odors.
✅【CONVENIENTLY HEAT YOUR FOOD IN MINUTES WITH FAST PTC HEATING TECHNOLOGY】Simply plug the lunchbox food heater into an electrical outlet or USB port, turn it on, and wait for it to heat up. Once it is ready, you can place your pre-cooked meal inside the container, and it will start warming up within minutes. The portable food warmer uses high-temperature PTC heating components that are energy-efficient and safe.
✅【SAFE & ENERGY-EFFICIENT】Electric heating lunch box is designed to be safe, with overheating protection and automatic shut-off to prevent accidents. It normally takes 25 minutes to warm the food at 25℃ and is also energy-efficient, consuming less power than conventional ovens or stovetops. This makes them an eco-friendly and cost-effective alterna
✅【SAY GOODBYE TO COLD LUNCHES WITH OUR DUAL FOOD HEATER】The low-power cycle heating design ensures that the food stays warm and refreshing for a long time without using too much energy. This dual-function heating and warming feature on the lunch box heater allows you to heat your food quickly and efficiently while keeping it at the perfect temperature for a satisfying lunch.
