Electric Lunch Box, 3 in 1 Food Heater Portable Microwave Electric Lunch Boxes with Insulation Bag for Car Truck Office 60W 12V 24V & 110V, 1.5L Stainless Steel Food Warmer and Heater Container (Grey)
Price: $22.74
(as of Aug 21, 2024 15:45:49 UTC – Details)
12131213
2121
Are you still eating your cold lunch? Research shows that more than 80% of staff have stomach problems.You need to change your lifestyle and protect your stomach. Using our electric lunch box is your best choice.
3333
Specifications:
Product Dimension: 9.4 x 6.7 x 4.3 Inch. Power Cable Length: 31 1/2″ (80 cm) Lunch Box Capacity: 1.5 L Small Box Capacity:0.3 L Heating Time: 30-40 minutes (when the room temperature is 25℃) Material: 304 Stainless Steel,PP Net Weight: 1.7 Lbs (0.77 kg)
541144541144
Package Contents:
1X Electric Lunch Box1X Insulated Lunch Bag 1X Stainless Steel Spoon 1X Stainless Steel Fork 1X Plastic Additional Compartment 1X Car/Trucks-use Charging Cable 12V 24V 1X Home-use Charging Cable 110V 1X User Manual
334334
2 in 1 Design
12V-24V for Cars/Trucks and 110V for Work/Home Use.Suitable for company office employees and truck driver who need to carry lunch by themselves
12131213
234234234234
21212121
Easy to clean
Contains a removable stainless steel tray,with 2 parts(a 1.5L stainless steel inner tray and a 0.45L plastic salad box.
Tips:Do not wash the lunch box as a whole into the water
Using Guidance
Put food in the lunch box.Plug in the correspondent plug.(when indicators light up, it means the food is heating)Make sure the steam outlet is opened.Enjoy the meal.
HEATING TIME
Summer: 30-40 MinutesWinter: 40-60 Minutes
Usually depend on your quantity of food,it will not exceed 1 hours.
🍱 CAR TRUCK & WORK DUAL USE – 2 in 1 Design,12V-24V for Cars/Trucks and 110V for Work/Home Use.Suitable company office employees and truck driver who need to carry lunch by themselves.Usually there are no microwaves around and eating out for lunch can get expensive,this electric lunch box is your best choice.
🍱 TOP GRADE SAFETY MATERIAL – Made of food grade PP plastic and 304 stainless steel container inner box for heat-preservation, anti-corrosion and long lifespan, PP plastic compartments also for food safety.Using high temperature resistant environmental materials.Stylish and fashionable appearance, without odor and healthy.Come with Free stainless steel spoon and fork for you,not like the others terrible plastic
🍱 ECO-FRIENDLY & FAST HEATING – Just plug in and heat.It is using PTC constant heating for preventing overheating,safer,more convenient and energy-saving.The design of recycle heating in low power keeps the food warm and fresh.it will keep constant heating between 60℃ and 70℃ when plugging in, always serving you a hot meal.You do not worry about eating cold food anymore
🍱 REMOVABLE & EASY TO CLEAN – Contains a removable stainless steel tray,with 2 parts(a 1.5L stainless steel inner tray and a 0.45L plastic salad box), you can put the rice and vegetables separately on the food tray. And there is a small compartment on the lid for placing spoon or fork.Safe clip lock on the lid for easy open and close. Easy to separate and clean.
🍱 AFTER SALE SERVICE – Come with a Portable Insulation Bag.Order from A-1UX for a true worry-free experience. We provide lifetime warranty and customer support.If you are already tired of eating the cold lunch,just Click “Add to Cart” and order our lunch box .If the lunch box has any problem,simply contact us for a replacement and taking advantage of our warranty.Tips:Do not wash the lunch box as a whole into the water. Make sure the cable plug is dry.
