Electric Long Lighter, Retractable Length (11.4in-27.55in), Lgnition Port Can be Rotated 360°, Rechargeable via USB, lighters Suitable for Lighting Candles, barbecues, fireplaces, fire pits, etc.
Price: $16.95
(as of Aug 11, 2024 04:15:41 UTC – Details)
extendable usb lighterextendable usb lighter
long lighterslong lighters
USB rechargeable electronic lighter
1. The USB rechargeable lighter can be recharged in many occasions and can be used continuously. You don’t need to worry about the fire source when you bring it when camping.
2. The lighter can be lengthened at will, keep a safe distance from the fire source, and no longer have to worry about burning your hands.
3. The ignition port can be rotated 360°, and the suitable direction can be adjusted to avoid the inconvenience caused by the uncontrollable direction during ignition.
4. We attach great importance to the quality and safety of our products. Materials and product designs have been strictly reviewed. Please use this product with confidence.
lighters for candlelighters for candle
Strong security protection
The handle of the candle lighter is far away from the ignition port, so it does not burn your hands when you light it like a traditional lighter. In addition to the ignition switch, the electronic lighter also has a power switch. This switch is to prevent the ignition switch from being accidentally touched. When the power switch is turned off, the ignition switch is invalid, which is very suitable for home use.
lighter rechargeablelighter rechargeable
candle lighter rechargeablecandle lighter rechargeable
long lighters for fireplacelong lighters for fireplace
long neck lighterlong neck lighter
windproof lighter
The lighter will not go out under the disturbance of strong wind.
How to stretch a lighter?
Grab the handle and stretch at the charging point to get the length you want.
360 ° flexible long neck
Rotate by hand to get the direction you want.
Easy to charge
The product comes with a USB charging cable and can be charged through any USB socket.
long grill lighterslong grill lighters
Product Dimensions ‏ : ‎ 11 x 0.8 x 0.8 inches; 5.29 ounces
Date First Available ‏ : ‎ December 8, 2021
Manufacturer ‏ : ‎ XIOKEMY
ASIN ‏ : ‎ B09N9TR2XW
