Electric Lighter Candle Long Lighters Rechargeable USB Plasma Grill Arc Windproof Electronic Flameless for Candle Fireplace BBQ Camping Kitchen Stick Cute with Safety Lock White
Price: $9.99
(as of Sep 04, 2024 11:30:28 UTC – Details)
WHY ELECTRIC LIGHTERSWHY ELECTRIC LIGHTERS
multi protect safety systemmulti protect safety system
chipchip
ignition2ignition2
Some tips
Please read carefully!
Use this electric lighter by Adult Only.Keep away from children.Lighters are NOT Toys.Don’t touch the ARC TIP of electric lighter.It’s hot during using.Use way from face,body,clothing and other flammable materials.Storge this candle lighter in dry enviornment and do not expose to high temperature above 120°F for long time especially in a car.Do NOT use this product in water or other liquids,or it may cause a short circuit.During the ignition,there will be the noise of “zee,zee”,which is high-voltage power generation,it’s low decibels that won’t hurt your ears.Please use with ease.Remember to close the bottom safety switch in time after use to ensure safe use and for power savingIf your candle lighter doesn’t ignite? Check to see if the power is suffcient.if a full charge still does not ignite, please contact our AFTER-SALES service.
Package Includes 1* Electric Lighter 1* Charging Cable 1* Gift Box 1* Instruction
safety locksafety lock
non-slip buttonnon-slip button
windproofwindproof
arc partarc part
Lighter with Safety Lock
The safety lock ensures that only when you push the lock to the right side can you use the lighter, which perfectly protects children’s accidental opening and avoid fingers from scalding. Designed at the bottom, it’s not easy to be unlocked by kids.
Lighter with Non-slip Switch
This arc lighter need to open double protective device to ignite.This is the second switch which is with non-slip design.
Windproof Design
Do you still worry about the flame being blown out by the strong wind? Don’t worry, the windproof design will protect the electric lighter from being blown out by strong wind.Perfect for both indoor and outdoor use.
Upgrade Ignition Head
ARC pulse is designed on the top, ignition is unlimited and more versatile.Also,the arc part is retractable.The new telescopic technology ensures the arc part sliding synchronously with the safety switch,which makes it safer when using this lighter.
giftgift
4.3 out of 5 stars
10
4.5 out of 5 stars
608
935
935
784
168
Quantity
1pc 1pc 1pc 2pcs 1pc 2pcs
Item Dimensions
6.3 x 0.59 x 0.59 in 6.97x 0.59 x 0.59 in 7.28x 0.59 x 0.59 in 7.28x 0.59 x 0.59 in 10.23x 0.59 x 0.59 in 10.23x 0.59 x 0.59 in
Item Weight
1.25oz 1.25oz 1.66oz 1.66oz 1.76oz 1.76oz
