Electric Candle Lighter, USB Rechargeable Lighter, Plasma Dual Arc Lighter, Windproof Flameless Lighter, with a Camouflage Leather case
Price: $7.99
(as of Aug 24, 2024 08:45:27 UTC – Details)
candle lightercandle lighter
electric candle lighterelectric candle lighter
Are you still using traditional lighters that pollute the environment, burn yourself easily, and waste money?
Are you still troubled by the fact that the lighter is not windproof or falls into the water and cannot be ignited when you go out camping?
PISFMUQS windproof arc lighter, completely solve your problem, adopt new arc ignition, windproof and waterproof, to meet all your ignition needs!
The Best GiftThe Best Gift
Arc LighterArc Lighter
candle lighterscandle lighters
rechargeable candle lighterrechargeable candle lighter
Plasma candle lighterPlasma candle lighter
Rotate 360 degrees
1.The best design is that it can be rotated 360 degrees. In addition to cigarette lighter, it can light candles, barbecue, etc., almost replacing all the functions of lighters. And you don’t have to worry about burning your fingers anymore.
Portable
1.candle lighter with portable design allows you to carry it with you conveniently, just keep it in your pocket and it’s ready to go.
2.In addition to lighting aromatherapy and candles, It’s also a perfect lighter for outside activities, like firework, camping, birthday party, and so on.
Safety Protection
1. Double switch, turn on the slider switch below, and then press and hold the ignition button above to ignite
2. If it is not used for 10 seconds, it will be powered off, and it needs to be turned off and turned on to use it.
3. Continuous ignition for seven seconds will automatically disconnect, you need to press and hold the ignition button again to use
Save money
USB cable included for your convenience to plug in the power to any USB or charger. Electric lighter without gas required, no fluid required, no flame. One-time charge can last more than 600 times. At least can be charged over 300 times.
Gift LightersGift Lighters
Candle LighterCandle Lighter
