Electric Bike for Adult, 26″ x 4.0 Fat Tire Ebike, 1000W/2000W Peak Electric Bicycle, 48V 13/17.5/23AH Waterproof Battery, Front Suspension Ebike, 27MPH-46MPH, Adjustable Seat, UL and GCC Certified
Price: $1,199.00
(as of Sep 29, 2024 12:30:17 UTC – Details)
【Hydraulic Disc Brakes & 7-Speed Gears】electric bike designed specifically for adults uses hydraulic disc brakes at the front and rear, which provides more effective braking in adverse conditions such as rainy weather, off-road, and long downhill slopes. The bike frame made of high-quality 6061 aluminum alloy, is lighter and more durable. Equipped with professional 7-speed gears, it is more accurate and stable.
【2000W Dual Brushless Motor】Q7 ebike for adults is equipped with 2X 1000W high-speed brushless motors which increases a stronger mountaineering performance, offering enough power for daily commuting. Top speed can reach 30MPH takes you to your destination quickly. Moreover, with 85nm of torque, can easily conquer various rugged terrains and steep hills.
【48V 23AH Large Capacity Battery】The dual motor e-bike with 48V*23Ah removable lithium-ion battery can travel more than 70 miles under pedal assist mode and can do up to 45 miles after each charge under the pure electric mode, which make sure you can reach the place you need, without having to worry about exhaustion of the power.
【26 x 4″ Fat Tire Electric Bicycles】2000 watt electric bike is equipped with 26“x 4” all-terrain fat tires having good grip and not easy to slip, and professional 7 -speed gear, can handle various rough surfaces. Besides, dual hydraulic disc brakes can quickly respond braking instructions, shorter braking distance give more secure exploration travel.
【5 Riding Modes & Updated LCD Display】Customize your ride performance with 5 riding modes including Pedal Assist, Throttle Mode, Normal Bike Mode, Cruise Control Mode, and Walk Mode . The color LCD display keeps track of real-time speed, battery level, pedal assist level, mileage ect.. Bright LED headlights and LED tail lights let other drivers see you and illuminate your path in low visibility situations.
【Easy Assembly & 24 Customer Service】85% of the mens electric bike pre-assembly, leave some simple parts for you to enjoy the fun (assembly handlebars, front wheels, headlights and front mud, pedals and seats). Professional warranty services for each electric bicycle. Please feel free to contact us at any time. Kind note: Please keep the original box for a while in case you want return the ebike.
