Electric Bike Conversion Kit, 48V 1000W 700C 28″/ 29″ Front/Rear Wheel Electric Bicycle Hub Kit Dual Mode Controller w/LCD Display & PAS, 5-Speed Adjustment E-Bike Conversion Kit
Price: $174.00
(as of Sep 29, 2024 08:00:20 UTC – Details)
Description
Our electric bicycle kit allows you to easily modify your bicycle. Our product includes a controller and PAS, as well as other necessary assembly tools, allowing you to purchase the necessary modification equipment in one go. The built-in brake allows you to directly apply the disc brake of your bicycle, making your riding safer.
Details
1. Storage Bag: You can use it to store the controller and secure it on the bike for easy use.
2. 7-Speed Rotary Flywheel: It can be adapted to variable-speed bicycles, allowing you to apply this product to various types of bicycles.
3. Rubber Tire: The rubber tire with patterns has a stronger grip and is less prone to slipping, making your riding safer.
Application
This product is suitable for 28″ bicycles with a rear fork opening size of 5.31 inches and can be used as a power device for variable-speed bicycles and general bicycles. It is suitable for bicycle lithium battery modification, DIY electric bicycles, electric folding bikes, etc.
Specification
Material: Rubber, Aluminum, 45# Steel, Aluminum Alloy
Color: Silver + Black
Installation Position: Rear
Power Type: 1* 48V Battery(Not Included)
Motor Type: Brushless Gearless DC Pure Copper Motor
Display Type: LCD
Voltage: 48V
Power: 1000W
Number of Flywheels: 7
Cable Head Width: 135mm/5.31in
Max. No-load Speed: 55km/34.18mile/h
Torque: 45N·m
Max. Load Capacity: 150kg/330.69lbs
Applicable Disc Brake Hole Spacing: 44mm/1.73in
Applicable Rear Fork Opening Size: 135mm/5.31in
Motor Wire Length: 1m/3.28ft
Wheel Diameter: 71.12cm/28in
Notes
1.Before use, please carefully read the product’s instructions and pay attention to the safety precautions.
2.When connecting the controller and wires, please make sure to connect the correct color to the controller. For your safety, please turn off the battery before connecting the controller!
Cycling Assistant – The PAS allows you to have three cycling modes: throttle, PAS, and manual. You can switch among appropriate cycling modes as needed. It can reduce fatigue, make the ride more comfortable, and is very suitable for long-distance travel.
Dual Mode Controller – The motor operates under both the Hall Effect and non-Hall effect, extending the service life of electric bicycles. If a component malfunctions, the controller will switch to non-Hall Effect mode, and the motor will still operate without affecting your use.
High Efficiency – The controller is a sine wave controller with high conversion efficiency. Coupled with a 1000W pure copper brushless gearless motor, this product can reach a speed of 34.18mph (no-load) and can travel further and faster.
Upgrade Display – The display shows real-time speed, maximum speed, average speed, total mileage, single mileage, battery power display, assist gear/speed grading, cruise function, so that you can charge in time and intuitively keep track of its operating status.
Safe and Reliable – The aluminum alloy wheel frame is very durable, stable, rust-proof and wear-resistant, ensuring long service life and strong load-bearing capacity, up to 330.69lbs. Comes with a brake, and you only need to connect the disc brake, making it convenient and safe to use.
