Price: $86.28
(as of Sep 29, 2024 17:00:17 UTC – Details)
Notes:During installation, it is necessary to adjust the angle to ensure that the front and rear wheels are in a straight line. This causes the force to tilt to one side all the time when the flywheel rotates, making it easy for the flywheel to be damaged.
Motor use freewheel so when wheel rotating, the motor will not rotate, just like a normal bike, this can reduce resistance.
This is our newest kit for electric common bike, this kit mounts the sprocket on the wheel spokes, so it fits most of bicycle wheel.
Important NOTE:This item is for the bike that uses the hub diameter less than 36mm.This item doesn’t include battery or charger.
The kit includes:
The twist kit includes:
1. 1x brush motor with freewheel
2. 1x Chain
3. 1x Customized sprocket & components
4. 1x Motor controller
5. 1x Mounting plate + bolts
6. 1x Twist throttle (with battery indicator & key switch)
The thumb kit includes:
2. 1x Chain
6. 1x Wuxing thumb throttle (with battery indicator & switch button)
Department : Unisex-Adult
Date First Available : May 15, 2024
Manufacturer : HWBWE
ASIN : B0D473TT6F
Country of Origin : China
【350W 36V】This item is for the bike that uses the hub diameter less than 36mm.
【Efficient】The 350W 36V brushless geared motor is powerful and efficient, which greatly improves riding comfort. It is suitable for station wagons, commuter vehicles and mountain bikes.
【Convenient】Easy to determine the Remaining Amount of Electricity, by turning the real-time voltage value can accurately determine the amount of the remaining amount of electricity.
【Easy To Use】By turning the real-time voltage value can accurately determine the judge the quality of lithium battery.To avoid traveling on the way without electricity and accurate judgment of the lithium battery is damaged.
【Easy To Install】Easily convert your pedal bike to an electric bike in 1 hour. If you don’t know well how to install, please contact us. This set of products has two riding modes (electric bicycles and pedal-assisted bicycles) for you to choose from, which can fully satisfy your exercise and commuting purposes.
