EF ECOFLOW Solar Generator DELTA2 with 220W Solar Panel, LFP(LiFePO4) Battery, Fast Charging, Portable Power Station for Home Backup Power, Camping & RVs
Price: $1,649.00
(as of Aug 20, 2024 18:00:17 UTC – Details)
11
22
1 2 3 4 1 High Conversion Rate 2 Carry Case 3 Weatherproof 4 Bifacial Design
1 2 3 4 1 Fast Charging 2 Expandable Storage 3 X-Stream 4 LIFePO4
1 2 3 4 1 APP Control 2 Portable&Light 3 How it Works 4 Power Anything
Runtime Drone (40Wh) 25 times 25 times 48 times 48 times 29 times 29 times CPAP (40W) 16 hrs 16 hrs 34 hrs 34 hrs 21 hrs 21 hrs Laptop (60Wh) 16 times 16 times 32 times 32 times 19 times 19 times Projector (65W) 12 hrs 12 hrs 24 hrs 24 hrs 13 hrs 13 hrs Mini Fridge (60W) 16-32 hrs 16-32 hrs 33-66 hrs 33-66 hrs 19-38 hrs 19-38 hrs TV (110W) 8 hrs 8 hrs 15 hrs 15 hrs 8 hrs 8 hrs Coffee Maker (1000W) 0.8 hrs 0.8 hrs 1.5 hrs 1.5 hrs 1.1 hrs 1.1 hrs Microwave (1300W) 0.6 hrs 0.6 hrs 1.5 hrs 1.5 hrs 0.9 hrs 0.9 hrs Air Fryer (1500W) 0.5 hrs 0.5 hrs 1.2 hrs 1.2 hrs 0.7 hrs 0.7 hrs Air Conditioner (1800W) 0.4 hrs 0.4 hrs 1-2 hrs 1-2 hrs 0.6-1.2 hrs 0.6-1.2 hrs Electric Kettle(1500W) 0.5 hrs 0.5 hrs 1.2 hrs 1.2 hrs 0.7 hrs 0.7 hrs Induction Cooker(1800W) 0.4 hrs 0.4 hrs 1 hr 1 hr 0.6 hrs 0.6 hrs
Clean, Green Charging. With up to 500W of solar panel input, DELTA 2 is a solar generator that can be charged while camping, on an RV trip or off-grid. Includes a 220W Bifacial solar panel to capture up to 25% more energy.
Built to Last 6x Longer. Its LFP battery chemistry makes for a portable power station with a 3000+ cycle life. Enough for years on end of use. With a sophisticated BMS, you can go easy knowing its an auto-regulating portable battery to keep you safe.
Power Almost Anything. Solar powered generator have come a long way. Power all your appliances with 1800W output, that’s on par with outdoor generators without the fumes or noise. With 15 outlets and its huge output, you can power 90% of your appliances.
Expandable Capacity from 1-3kWh. With the standalone portable power station sporting 1kWh, you can add on extra batteries to reach up to 3kWh. Ideal for camping, RVs or home backup power.
What you Get. DELTA 2 Power station, 220W Solar panel, Adjustable kickstand case, AC charging cable, Car charging cable, Solar charging cable, DC5521 to DC5525 cable, User manual, and an exclusive 5 customer service.
*DELTA 2 and 220W Portable Solar Panel will be shipped separately.
