EF ECOFLOW Solar Generator DELTA Max (2000) 2016Wh with 220W Solar Panel, 6 X 2400W (5000W Surge) AC Outlets, Portable Power Station for Home Backup Outdoors Camping RV Emergency
Price: $2,299.00 - $1,299.00
(as of Jul 21, 2024 20:15:20 UTC – Details)
solar generatorsolar generator
solar generator solar generator solar generator 1 X-Stream 2 X-Boost 3 AC Output
Solar Generator DELTA 2 Max Solar Generator DELTA 2 Max solar generator 1 Fast Solar Charging 2 Bifacial Design 3 Charging Methods
Fast Solar Charging: With up to 800W of solar input, DELTA Max is a solar powered generator that charges fast. With a single 220W panel, you can charge in 11.5 hours. Ideal for power outages.
Large Capacity: 2016Wh of energy stored means you can use it as an outdoor generator, or indoors for backup power. Keep appliances going for hours on end.
Clean, Green & Quiet: Replace your traditional gas generator with a solar generator. No fumes, totally portable, no noise and renewable charging. Compatible with both EcoFlow solar panels and select third-party models.
Power Pretty Much Anything: With X-Boost technology, DELTA Max can power almost all your home appliances and devices up to 3400W. Great for power outages, camping or RV trips.
Lightweight & Waterproof: 220W double-sided solar panel is foldable and compact, weighing only 21 lb, making it easy to carry or store. With a thin tempered glass design, it’s 5 times more durable than similar solar panels. Its IP68 rating makes it both water-resistant and dustproof.
Control From Afar: With the EcoFlow app, you can monitor your portable power station, control it & more. All the while the internal BMS keeps you safe.
