EF ECOFLOW Solar Generator DELTA Max (2000) 2016Wh with 160W Solar Panel, 6 X 2400W (5000W Surge) AC Outlets, Portable Power Station for Home Backup Outdoors Camping RV Emergency
Price: $1,899.00 - $1,249.00
(as of Jul 26, 2024 10:45:09 UTC – Details)
22
DELTA Max (2000) + 160W Solar Panel Bundle
Make the most of renewable and cost-saving solar energy for DELTA Max.
DELTA Max(2000) can achieve better performance under different weather conditions with MPPT(Maximum Power Point Tracking) smart algorithm. And the solar panel is built for portability and durability with portable and adjustable kickstand case, high-quality materials, one-piece waterproof design.
How do we ship our products?
A: Due to the big size of EcoFlow Power Stations & Solar Panels, we will ship separately if your order has multiple products including portable power stations and foldable solar panels.
Why does the battery lose power when not in use?
A: The unit may be in standby mode where the power supply, screen, and/or inverter could be using up to 50W. Remember to long press the power button to turn the unit completely off. If the unit loses power when completely off, try recharging it to 100% and use it to 0% two or three times to calibrate the battery. If the problem persists, please contact customer support.
A+A+
A+A+
A+A+
Waterproof ip67Waterproof ip67
11
4.3 out of 5 stars
844
4.6 out of 5 stars
552
4.6 out of 5 stars
552
4.6 out of 5 stars
552
4.5 out of 5 stars
593
4.5 out of 5 stars
593
$1,299.00$1,299.00 $2,499.00$2,499.00 $3,199.00$3,199.00 $2,999.00$2,999.00 $599.00$599.00 $699.00$699.00
Solar Panel
220W 220W 2x220W 400W 160W 220W
Solar Charging
9.2hrs 9.3hrs 4.7hrs 5.1hrs 4.8hrs 3.5hrs
Phone
175 times 143times 143times 143times 57 times 57 times
Refrigerator
14-28 hrs 14 hrs 14 hrs 14 hrs 6.1-12.2hrs 6.1-12.2hrs
Coffee maker
1.9 hrs 1.6hrs 1.6hrs 1.6hrs 0.8 hrs 0.8 hrs
Electric grill
1.7 hrs 1.4 hrs 1.4 hrs 1.4 hrs 0.8 hrs 0.8 hrs
Microwave
1.5 hrs 1.3 hrs 1.3 hrs 1.3 hrs 0.8 hrs 0.8 hrs
50″ TV
15 hrs 15hrs 15hrs 15hrs 5.6 hrs 5.6 hrs
Endless Solar Power. EcoFlow DELTA Max(2000) MPPT Controller guarantees full recharge with 160W solar panels with zero pollution emission. Use it as a solar powered generator for your home by powering appliances and tools on renewable energy.
Power Pretty Much Anything. 2400W output to power up to 15 devices at once. Power 3400W appliances with X-Boost on. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That’s the industry gold standard for a portable power station of this size and capacity.
Waterproof & Durable. EcoFlow 160W solar panel is waterproof to endure all weather conditions, ideal for outdoor activities such as camping, climbing, hiking. You can submerge the panel in water for up to 30 minutes with no detrimental effect to the product.
Multiple Charging Methods. More than a solar power station. Charge with AC, solar, car or the EcoFlow Dual Fuel Generator. Charge to full in 1.8hrs via wall outlets. Use Dual Charging to combine AC with the Smart Generator for industry leading speeds. Pair solar + AC, or Solar + the Smart Generator for outdoor use.
Smart Remote Control with EcoFlow App. Control and monitor your DELTA Max with the EcoFlow app. Dive into the settings to customize your power use or control DELTA Max remotely. To ensure prompt delivery, please note that the DELTA Max(2000) Solar Generator and 160W Solar Panel will be shipped separately. If you receive one item before the other, kindly await the arrival of the remaining item.
