Price: $208.00
(as of Aug 25, 2024 13:15:29 UTC – Details)
FAQ
Q1: What devices can RIVER run?
A: With EcoFlow X-Boost technology, RIVER can power devices up to 1200W. However, X-Boost is not applicable for all electrical appliances, some 600-1800W appliances with strict voltage requirements may not function. In addition, if the instantaneous power of the electrical appliance exceeds 1200W (with the X-boost function turned off), exceeding 1800W (with the X-boost function turned on) will also cause the power supply to be overloaded and unusable. (eg. air conditioners/fridge-freezer/microwave/oven).
Q2: How long will RIVER run my device?
A: Generally, run time ≈ 288Wh*0.85/operating wattage of your device. The inverter efficiency of different output power is different, so the use time of the electrical appliance is also different according to the different efficiency.
Q3: Why does the battery lose power when not in use?
A: The unit may be in standby mode where the power supply, screen, and/or inverter could be using up to 50W. Remember to long press the power button to turn the unit completely off. If the unit loses power when completely off, try recharging it to 100% and use it to 0% two or three times to calibrate the battery. If the problem persists, please contact customer support.
NOTE:
[1]. Upgrade to the latest firmware on the EcoFlow app to enjoy a better user experience;
[2]. Appliances have been tested on a case-by-case basis. If you would like to power heavy-duty devices, please conduct a full test;
[3]. RIVER Series AC charging cable couldn’t be used with DELTA.
[4]. Store in dry and well-ventilated place. If exposed or used in a humid environment for a long time (E.g. seaside), we recommend you use a waterproof bag to keep your battery dry.
[5]. If you accidentally drop the product into water or spill water on the battery during use, please place it in a safe open area, and stay away from it until it is completely dry. The dried product should not be used again.
RECHARGE FROM 0% TO 80% WITHIN 1 HOUR: With EcoFlow’s patented X-Stream Technology, the smart inverter enables a fast rechargeability that takes less than 1 hour to charge from 0% to 80%, and it gets fully charged in 1.6 hours. You can switch to a quieter charging condition by turning on the “Quiet Charging” status on the APP.
COMPATIBLE WITH 80% of HOME APPLIANCES: The X-Boost Technology’s advanced built-in algorithm enables most heavy-duty kitchen appliances and tools (up to 1800W) to operate. With X-Boost, RIVER can power 80% of essential home appliances and devices, especially those within 1200W for better using experience. The discharging rates and X-Boost mode can be monitored and controlled through the EcoFlow APP.
3 x 600W AC OUTLETS AND 288Wh CAPACITY: The RIVER can power up to 10 devices simultaneously. With 3 pure sine wave AC outlets, the RIVER can power devices up to 1800W with the X-Boost mode on. With a capacity of 288Wh, the RIVER provides enough juice to run essential devices for hours, depending on the actual output.
FIT YOUR NEEDS, NOW AND LATER: Double the capacity from 288Wh to 576Wh with Extra Battery, the modular design of RIVER, is the power that grows with your needs. Designed for mobility, the 11 lbs solid yet lightweight RIVER is slightly larger than a toaster, which is perfect to take out. You can easily double the capacity of the RIVER from 288Wh to 576Wh by integrating with an Extra Battery.
24 MONTHS WARRANTY: EcoFlow offers a 24*7 friendly customer service, and a 24 months product warranty. What’s in the box: 1* RIVER 288Wh portable power station, 3 types of charging cable (1*1.5M AC Charging Cable, 1*1.5M Car Charging Cable, 1*User Guide.
