Price:
(as of Jul 21, 2024 08:45:12 UTC – Details)
About EcoFlow
Our mission is to empower both individuals and communities through portable, clean, and reliable power, by replacing the traditional gas generator and reinventing the way the world accesses energy.
Fresh Arrivals: DELTA Pro 3
Solar Tax Credit Available
DELTA Series
RIVER 2 Series
[Fastest Charging in the Industry] – Fully recharge using an AC outlet in only 70 minutes with EcoFlow’s X-Stream fast charging technology.
[Power 80% of Your Appliances] – With an output of up to 1600W, run 80% off all your appliances, even high wattage ones. With 11 outlets, from 800W AC outlets to USB-C, simultaneously charge or run all your devices without worrying about overloading.
[LFP Long-Life Battery] – Using LFP battery cells, use and recharge RIVER 2 Pro more than 3000 times before hitting 80%. That’s almost 10 years of regular use. RIVER 2 Pro includes advanced BMS protection, monitoring voltage, current, and temperature to keep your LFP battery running for years.
[Fast Solar Charging] – Use clean, green renewable energy to recharge RIVER 2 Pro, in as fast as 3.5 hours with 220W solar input.
[Light & Portable] – With a lightweight of only 17.2 lbs, RIVER 2 Pro is the ideal outdoor generator for all your off-grid adventures. With a built-in handle, this portable battery is easy and convenient to take anywhere you need power.
[What’s included] – RIVER 2 Pro portable power station, AC charging cable, Car charging cable, DC5521 Connection Cable, User manual, and a 5-year service.
