EF ECOFLOW Portable Power Station RIVER 2, 256Wh LiFePO4 Battery/ 1 Hour Fast Charging, 2 Up to 600W AC Outlets, Solar Generator (Solar Panel Optional) for Outdoor Camping/RVs/Home Use
Price: $289.00 - $168.00
(as of Jul 21, 2024 05:00:20 UTC – Details)
portable power station solar generator LiFeP04 Battery Backup outdoor generator electric generator portable power station solar generator LiFeP04 Battery Backup outdoor generator electric generator camping generator portable generator for home use home battery backup battery inverter power station 1 RIVER 2 VS Gas Generator 2 10-Year Lifespan 3 Ultra Safe
home battery backup battery inverter power station power bank with ac outlet ef ecoflow river 2 portable power station solar generator LiFeP04 Battery Backup outdoor generator electric generator camping generator portable generator for home use home battery backup battery inverter power station camping generator portable generator for home use home battery backup battery inverter power station 1 1H AC Recharge 2 Solar Recharge 3 12V Car Recharge 4 USB-C Recharge
home battery backup battery inverter power station power bank with ac outlet ef ecoflow river 2 home battery backup battery inverter power station power bank with ac outlet ef ecoflow river 2 home battery backup battery inverter power station power bank with ac outlet ef ecoflow river 2 portable power station solar generator LiFeP04 Battery Backup outdoor generator electric generator 1 Up to 600W Output 2 Smart APP Control 3 Lighter Than a Cat 4 Emergency Power Supply
portable power station solar generator LiFeP04 Battery Backup outdoor generator electric generatorportable power station solar generator LiFeP04 Battery Backup outdoor generator electric generator
How long can the RIVER 2 power my appliances?
Run time≈256Wh*0.85/operating wattage of your appliances.
Can the RIVER 2 be used as an uninterruptible power supply (UPS)?
When your RIVER 2 is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER 2 automatically switches to its battery supply mode within 30 milliseconds.
Can the RIVER 2 handle high-wattage appliances?
Yes. The RIVER 2 can power devices up to 600W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 600W, however, it’s best to test before use.
What kind of solar charger can charge the RIVER 2 solar generator?
The RIVER 2 electric generator can be charged with type-c solar panel if there is a stable 5/9/12/15/20V 3A output.
Runtime
4.3 out of 5 stars
2,541
4.5 out of 5 stars
1,545
4.5 out of 5 stars
570
4.2 out of 5 stars
867
4.5 out of 5 stars
1,486
$168.00$168.00
$379.00$379.00
$199.99$199.99
$479.00$479.00
Phone 11Wh (Type-C)
19 times
38 times
57 times
23 times
59 times
Camera 16Wh (USB)
13 Times
26 times
39 times
16 times
40 Times
Drone 40Wh (Type-C)
5 Times
10 times
15 times
6 times
16 times
Laptop 60Wh (Type-C)
3.4 Times
6.8 times
10 times
4 times
10 times
WiFi Router 10W (AC)
7.9 hrs
15.8 hrs
23.7 hrs
8.9 hrs
22.2 hrs
CPAP 40W (AC)
4.6 hrs
9.2 hrs
13.8 hrs
4.8 hrs
12 hrs
Fan 40W (AC)
4.6 hrs
9.2 hrs
13.8 hrs
4.8 hrs
12 hrs
Mini Fridge 60W (DC)
3.1-6.2 hrs
6.2-12.4 hrs
9.3-18.6 hrs
3.5-7 hrs
10.8-21.6 hrs
[1 Hour AC Recharge] – Fully recharge the electric generator using an AC outlet in only 1 hour with EcoFlow’s X-Stream fast charging technology.
[Power All Your Essentials] – With an output of up to 600W, run 6 essential appliances simultaneously without worrying about overloading. With a whole host of ports, from 300W AC outlets to USB-C, we’ve got all your device’s plugs covered.
[LFP Long-Life Battery] – Using LFP battery cells, use and recharge RIVER 2 more than 3000 times before hitting 80%. That’s almost 10 years of regular use. RIVER 2 includes advanced BMS protection, monitoring voltage, current, and temperature to keep your LFP battery running for years.
[Fast Solar Charging] – Use clean, green renewable energy to recharge RIVER 2 power generator in as fast as 2.3 hours with 110W solar input.
[Light & Portable] – With a lightweight of only 7.7 lbs, RIVER 2 is the ideal outdoor generator for all your off-grid adventures. With a built-in handle, this portable battery is easy and convenient to take anywhere you need power.
[What’s included] – RIVER 2 portable power station, AC charging cable, car charging cable, user manual, and a 5-year service.
