Price: $1,598.00
(as of Aug 23, 2024 03:30:17 UTC – Details)
EcoFlow’s DELTA Series is recognized by some of the most prestigious international awards. The flagship product of the Series – DELTA Pro, was named in TIME’s list of 100 Best Inventions of 2021. It also won the 2022 Red Dot Design Award along with its ecosystem accessories. The 2022 iF DESIGN AWARD named the DELTA Pro, DELTA Max, 400W Solar Panel, and Smart Generator the winners in the product discipline.
Prepare for Hurricane Outages
Fresh Arrivals: DELTA Pro 3
Solar Tax Credit Available
Prime Choice
DELTA Series
RIVER Series
1.8 Hrs to Full Charge. EcoFlow’s patented X-Stream AC fast charging lets you recharge DELTA Max in only 1.8 hours. Or even quicker if you combine any two charging methods, that’s from an AC wall outlet, solar panels, or a Dual Fuel Generator.
2-6kWh Expandable Capacity. DELTA Max’s large 2kWh capacity keeps your home appliances running during a blackout. Expand up to 6kWh with Extra Batteries, keeping your home powered on in any emergency.
Power Heavy-duty Devices with 2400W Output. 2400W output to power up to 15 devices at once. Power 3400W appliances with X-Boost on. That means during a power outage or blackout, you can continue to power your fridge, microwave, dryer, and more. Ideal power generator for backup power.
Solar Charge in as fast as 2.5 Hrs. Connect solar panels of up to 800W to keep DELTA Max running even when there’s an outage. Compared to gas generator, the cost of gas, noisy operation, maintenance make DELTA Max a good long-term investment.
Monitor and Control from the EcoFlow App. Take control of your DELTA Max and quick-view stats right from your phone. Customize settings such as charging speeds and Dual Fuel Generator auto-start levels to fit your power needs.
