EF ECOFLOW Portable Power Station 3600Wh DELTA Pro, 120V AC Outlets x 5, 3600W, 2.7H Fast Charge, Lifepo4 Power Station, Solar Generator for Home Use, Power Outage, Camping, RV, Emergencies
Price: $3,599.00
(as of Aug 01, 2024 17:30:19 UTC – Details)
DP3DP3
ecoflow logoecoflow logo
EcoFlow’s DELTA Series is recognized by some of the most prestigious international awards. The flagship product of the Series – DELTA Pro, was named in TIME’s list of 100 Best Inventions of 2021. It also won the 2022 Red Dot Design Award along with its ecosystem accessories. The 2022 iF DESIGN AWARD named the DELTA Pro, DELTA Max, 400W Solar Panel, and Smart Generator the winners in the product discipline.
Fresh Arrivals: DELTA Pro 3
Solar Tax Credit Available
Prime Choice
ifif
MediaMedia
DELTA Series
RIVER Series
ALL PRODUCTSALL PRODUCTS
【30% Tax Credit Could be Applied】You could apply for the Residential Clean Energy Credit for qualified solar electric property costs. Please check with your utility to verify eligibility & requirements for Residential Clean Energy Credit programs.
【Large Capacity】Featuring a 3600Wh LFP battery capacity, DELTA Pro provides strong electrical storage for home battery backup power supply and outdoor camping. Applied with DELTA Pro Extra Batteries or Smart Generators, the electric generator can expand its capacity from 3.6kWh to 25kWh.
【Maximum Output Flexibility】A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. You can even pair two units together to achieve 7200W. Power 99.99% heavy-duty devices at home, outdoors, or at work. With 15 output methods: 2*USB-A, 2*USB-A Fast Charge, 2*USB-C (100W), 5*AC Outlets, 2*DC Outlets, 1 car power output and 1 Anderson port, the solar power station grants the ability to power multiple devices at the same time.
【X-Stream Fast Charging】Fully recharge the lifepo4 battery in 1.8 hrs with 240V outlets(3000W), 2.7 hrs with 1800W wall outlets or solar charged in 2.8 hours with 4*400W solar panels thanks to the industry-leading solar conversion efficiency of up to 23%. EcoFlow’s X-Stream charging technology isn’t just fast, it’s safe too with the battery management system.
【5 Ways to Charge】Pick from EV station charging, solar, wall outlets, using the smart outdoor generator or via a car outlet. Faster than any other 3000 watt solar generator. Keep going for miles when your electric vehicle runs out of battery. Either at home or on the go, DELTA Pro will have you back on the road in no time.
【Smart App Control】Use the EcoFlow app via Wi-Fi or Bluetooth. Monitor the status of all your devices and power sources that are charging your portable power station. Check on charge level, temperature and charge/discharge times. Control from afar and customize all settings, such as battery life, input/output, and more. Break down your energy habits or customize your energy usage to fit your needs.
