EF ECOFLOW DELTA Max (1600) Portable Power Station, 1612Wh Expandable Capacity with 6 x 2000W (5000W Surge) AC Outlets, Solar Generator for Home Backup, Emergency, Outdoor Camping or RV Travel
Price: $1,039.00
(as of Aug 10, 2024 16:15:13 UTC – Details)
DP3DP3
ecoflow logoecoflow logo
EcoFlow’s DELTA Series is recognized by some of the most prestigious international awards. The flagship product of the Series – DELTA Pro, was named in TIME’s list of 100 Best Inventions of 2021. It also won the 2022 Red Dot Design Award along with its ecosystem accessories. The 2022 iF DESIGN AWARD named the DELTA Pro, DELTA Max, 400W Solar Panel, and Smart Generator the winners in the product discipline.
Fresh Arrivals: DELTA Pro 3
Solar Tax Credit Available
Prime Choice
ifif
MediaMedia
DELTA Series
RIVER Series
ALL PRODUCTSALL PRODUCTS
【Huge Expandable Capacity】 – Large 1612Wh capacity for home backup which can be expandable up to 5644Wh with extra battery connected (1.6kWh to 5.6kWh can support one to three days family emergency use).
【Power Pretty Much Anything】 – With a total of 2000W AC output and 15 outlets (6*AC outlet, 2*USB-A, 2*USB-A fast charge, 2*USB-C, 1*Car power outlet, 2*DC5521) to play with, DELTA Max is able to power 99% home appliances. It can support up to 2800W device and prevent overload from using the high-power devices with the X-Boost mode on.
【Multiple Charging Methods】 – More than a solar generator. Charge with AC, solar, car or the EcoFlow Smart Generator. Charge to 80% in under 1hr via wall outlets. Use Dual Charging to combine AC with the Smart Generator for even faster speeds. Pair solar + AC, or Solar + the Smart Generator for outdoor use.
【Safety First】 – Advanced battery management system (BMS) monitor and protect your products in real-time usage. The optimized unibody design and fire-resistant materials increase the reliability.
【What You Can Get】-1x DELTA Max(1600), 1x AC Charging Cable, 1x Car Charging Cable, 1x Solar Charging Cable, 1x DC5521 to DC5525 Cable, 1x User Manual.
