EF ECOFLOW 10.8kWh Portable Power Station: DELTA Pro with 2 Extra Battery, 120V Lifepo4 Battery Backup with Expandable Capacity, Solar Generator for Home Use, Power Outage, Camping, RV, Emergencies
Price: $3,199.00
(as of Aug 25, 2024 01:45:26 UTC – Details)
TAXTAX
ecoflow logoecoflow logo
EcoFlow’s DELTA Series is recognized by some of the most prestigious international awards. The flagship product of the Series – DELTA Pro, was named in TIME’s list of 100 Best Inventions of 2021. It also won the 2022 Red Dot Design Award along with its ecosystem accessories. The 2022 iF DESIGN AWARD named the DELTA Pro, DELTA Max, 400W Solar Panel, and Smart Generator the winners in the product discipline.
11
Prepare for Hurricane Outages
Solar Tax Credit Available
ifif
MediaMedia
DELTA Series
RIVER Series
ALL PRODUCTSALL PRODUCTS
【30% Tax Credit Could be Applied】You could apply for the Residential Clean Energy Credit for qualified solar electric property costs. Please check with your utility to verify eligibility & requirements for Residential Clean Energy Credit programs.
【Expandable Capacity】With 2 Extra Batteries, DELTA Pro can expand capacity from 3.6kWh to 10.8kWh for battery backup power supply. A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W. Replace noisy, smoky generators with a silent, fume-free home backup power station.
【X-Stream Fast Charging】Fully recharge the DELTA Pro in 1.8 hrs with 240V outlets(3000W), 2.7 hrs with 1800W wall outlets or solar charged in 3.5-7 hours with 3*400W solar panels thanks to the industry-leading solar conversion efficiency of up to 23%. Ideal for juicing up the battery between short outages. EcoFlow’s X-Stream charging technology isn’t just fast, it’s safe too with the battery management system.
【5 Ways to Charge】Pick from EV station charging, solar, wall outlets, using the smart outdoor generator or via a car outlet. Faster than any other 3000 watt solar generator. Keep going for miles when your electric vehicle runs out of battery. Either at home or on the go, DELTA Pro will have you back on the road in no time.
【Smart App Control】Integrate DELTA Pro with your home using the EcoFlow Smart Home Panel, then use the EcoFlow app to break down your energy habits or customize your energy usage to fit your needs. The EcoFlow DELTA Pro ecosystem stores energy during the day, reducing your reliance on the grid and lowering your bills by combating peak energy rates.
【15 Versatile Outputs】DELTA Pro includes 15 outlets and ports: 5*AC outlets, 4*USB-A ports, 2*USB-C ports, 2*DC ports, 1*car power output and 1*Anderson port. Power all your devices such as cell phone, iPad, tablet, camera, radio, projector, night light, mini fan and so on.
Kindly note that the power station and each extra batteries will be shipped in different packages.
