Price: $235.99
(as of Aug 06, 2024 08:00:18 UTC – Details)
EENOUR Power Station 2000Wh
1.5H Fast Full Recharge
P2001 can achieve 1.5H fast recharge from 0 to 100% by 1100AC and 500W Solar Input.
Solar Generator, Green Power
2000W Output, 4000W Surge
Power Your Devices Anywhere
[POWER MONSTER] – With the remarkable 2,000Wh of capacity and AC Max output 2,000W (4,000W Peak), this P2001 power station can power 99% of home devices, giving you confidence in any occasions. Perfect for outdoor off-grid activities including camping and RV, whilst suitable for home emergency use. Powering a host of your appliances – fridge, air conditioners, blenders, electric stoves, electric microwave ovens and more
[MORE THAN FAST RECHARGING] – 1.5 hours from 0% to 100% made possible by 1100W AC input + 500W Anderson input. With a simple and speedy setup in 60 seconds, you can enjoy endless green power wherever you go. Bonus: full AC wall charge in 1.8 hours
[16 VERSATILE OUTLETS] – 6 AC ports, 2 USB-C (PD 100W), 2 USB-A (QC 3.0), 2 USB-A, 2 DC output, 1 car cigarette lighter outlet, 1 XT60 output always can service your various needs. This all-in-one power station is an indispensable choice for your DIY work, household emergency, power outage, Hurricans, going out camping, or traveling
[UPS MODE DOUBLE PROTECTION] – Connect the power station between the wall outlet and devices, the power station will automatically switch to the UPS power supply mode within 10ms when there is a sudden power failure such as blackout, voltage sag, or voltage surge. To keep safe and continuous working for the computer, refrigerator, CPAP machines, and other equipment below 1100W
[3500+ LIFE CYCLES to 80%] – The ultra-safe LiFePO4 battery cells and premium BMS tech offer multiple protections to your P2001, making it a reliable power backup that can last longer than a decade
[23.5% High Conversion Efficiency] – 200-Watt monocrystalline solar panel is with a higher conversion efficiency of up to 23.5% and can generate 200W max output solar power, enabling fast and quiet charging for your solar generators. Besides, the monocrystalline silicon solar panel is more durable and with a long using life.
[18V/36V Switchable & 200W Output] – As the latest technology in the industry, the output voltage of the 200-watt solar panel can be switched between 18V and 36V, and the functionality has been improved compared to solar panels on the market that only have 18V. Moreover, solar panels support series/parallel connection.
[WHAT YOU GET] – 1*EENOUR P2001 Power Station , 1*AC charger, 1*Solar Charging Cable, 1*Car Charging Cable; 1*EENOUR 200W Solar Panel (built-in 1× MC4 Cable, 2×QC 3.0 USB-A , 2×PD60W Type-C Outputs, 4×Adjustable Kickstands)
