EcoSmart ECO 11 Electric Tankless Water Heater, 13KW at 240 Volts with Patented Self Modulating Technology
Price: $299.00 - $198.24
(as of Jul 30, 2024 05:30:26 UTC – Details)
Endless On-Demand Hot Water; Consistent hot water when you need it that never runs out; Continuously monitored water temperature and controlled flow rates ensure efficiency and consistent performance within 1 degree of selected temperature.Amperage Draw : 54 A.Special Features: ‎Energy Efficient
Save Space; EcoSmart tankless electric water heaters are 90% smaller than traditional tank heaters; may be installed on wall or at point of use; Dimensions 11.5 x 8 x 3.75 inches
Save Energy; EcoSmart tankless electric water heaters are 99% thermal energy efficient; Only heats water when called unlike a tank heater that maintains water temperature even when not being used.
EcoSmart ECO 11 Sizing; 13-kilowatt tankless electric water heater ideal for providing hot water for a bathroom, small sink, office breakroom and other point-of-use or low-flow applications; provides between 1.3 and 3.1 gallons-per-minute depending on the inlet water temperature; refer to the sizing guide to select the proper solution
