Price: $1,499.00
(as of Aug 10, 2024 04:30:18 UTC – Details)
The DuroMax XP13000EH is a Dual Fuel workhorse powered by a 500cc OHV Engine and runs on gasoline or propane. This unit provides the power normally found in stationary home standby units but in a portable package. With 10,500 watts of running power and the ability to surge up to 13,000 watts, this generator can power household essentials such as lights, small and large appliances, and your home’s central A/C system. The fully loaded power panel features multiple outlets including 2 120V GFCI protected household outlets, and individual breakers to prevent overloading and keep everything safe. This unit is both EPA and CARB approved for operation in all 50 states.
With 13,000 watts of power, the XP13000EH Dual Fuel generator will keep your whole home running during a storm or power outage
DuroMax is the industry leader in Dual Fuel portable generator technology, with a full assortment ranging from digital inverters to generators that can power your entire home
At the core of all our products resides a robust DuroMax engine. Designed for Power. Designed to Last
The XP13000EH comes with a push button start, a front facing interface that allows you to change your fuel type in seconds, and a wide variety of outlets (including a transfer switch-ready 50 amp outlet)
Constructed with a heavy-duty all metal frame and power panel – No plastic parts
Built to withstand severe weather and years of heavy wear-and-tear
Power wherever and whenever you need it – No-flat tires roll easily over any terrain
100% Copper Windings – Unlike aluminum, copper is a superior heat conductor that extends the life of your generator
Stay powered with our EH line of portable generators
DuroMax portable generators are designed to be mobile and versatile, with the ability to provide power whenever and wherever you need it. Unlike traditional standby generators that are large, expensive, yet only serve one purpose, DuroMax generators will power you whether you’re at home, on an RV trip, or at the jobsite
