Dual RV Backup Camera System Upgraded: No Lag Easy Installation Plug and Play 7″ Monitor HD 1080P Rear View Camera Wired Kit IP69 Waterproof IR Crystal Night Vision for Truck Trailer Camper Tractor R4
Price: $89.99
(as of Aug 16, 2024 03:00:26 UTC – Details)
Rohent R4 Wired RV Backup Camera with Monitor System rv backup camerarv backup camera
Backup camera for truck system is a wired backup camera system. No need to worry about signal loss and signal interference
Safe Driving, Happy Life truck cameratruck camera
Crisp and Sharp Images NO Video Lag,so you can see your surroundings when you’re driving in reverse
The 7 Inch Monitor Can Support Two Cameras AHD1/AHD2 rear view backup camera kitrear view backup camera kit
Monitor automatically turns on and switch to AH2 rear view picture when reversing.Second License Plate Camera Available. AH1 camera can be as Continuous Viewing,AH2 camera can be as used for horse trailer/front facing view/hitching the RV or trailer behind.
Wired Trailer Camera with 170 Degree Wide Angle View reverse camera for truckreverse camera for truck
Backup camera with monitor suitable for RV, 5th Wheel, Truck,Trailers, Campers, Bus and different type of vehicles
trailer backup camera
International Standard IP69 waterproof level,the camera can work well in all weather conditions
back up camera trailer backup camera
Infrared lights provide excellent night vision performance
backup camera for truck reverse camera 1 100% Waterproof 2 Cold and Heat-Resistant 3 Upgrade Chip and Sensor 4 Metal Material 5 Crystal Night Vision
Easy DIY installation in 30Min: Backup camera for truck trailer is a breeze to install with its plug and play setup; connect it to your car charger with an on/off switch or directly to your 12V-24V reverse circuit system
Stable signal transmission: Get HD 1080P clarity with stable and strong signals that are free of interference; reverse camera for truck provides superior signal quality
Clear night vision: Back up camera for truck rv has true IR night vision; allowing for crystal-clear images in low-light situations; see up to 80 feet with the latest infrared technology
Wide Viewing Angle: With a 170-degree field of view; truck backup camera is a great helper for reversing and parking at night; get excellent clear images on rainy days
100% Waterproof wired backup camera: Industry standard IP69 waterproofing ensures complete protection against all kinds of weather; providing peace of mind for the long haul
DIY parking grid lines and image flip: The backup camera for rv lets you adjust the parking grid lines to portray real-life conditions; as an added convenience, you can also toggle the parking guide lines on and off
Dual channels: RV camera system is 2 camera capable; making it perfect for backing security and other purposes; you can replace the second rv camera with a license plate camera for varying viewpoints and the V2 video input has priority for safety
Warm hint for R4 backup camera with monitor: The included bracket adapter can be customized to fit your needs and the 23 ft 33 ft or 43 ft video cable connects the camera to the monitor directly; the large 7 inch display can be mounted on the dashboard or windshield
