Price: $399.99 - $299.99
(as of Aug 12, 2024 20:15:22 UTC – Details)
Prepare for all you need
In 2019, Dr.Prepare has started with the mission of providing cost-effective solutions for you and your family,
U.S. local warehouse
With our U.S. local warehouse and lifetime expert support, we are committed to offering a satisfying shopping experience for you all.
12V 100 Ah LiFePO4 Battery
LiFePO4 Battery
LiFePO4 Battery with Meter
Mini LiFePO4 Battery
14.6V LiFePO4 Battery Charger
Group 31 LiFePO4
LiFePO4 Battery with Screen
2 Packs of LiFePO4 Batteries
2 pcs of 12V 100Ah Batteries in PARALLEL for expanding to 12v 200Ah2 pcs of 12V 100Ah Batteries in SERIES for expanding to 24v 100Ah
Maximum 16 Packs of LiFePO4
Connected up to 16 batteries in PARALLEL and SERIES, expanding to 20.48 kWh
10 – year customer support
10 – year lifespan
Local warehouse in the U. S.
Cold temp cute off protection
Over-current cutoff, over-charge cutoff, over-discharge cutoff, high cutoff, short circuit protection
LED screen to display capacity and voltage in real-time
Great support for parallel and series connections
What problem are we solving?
Dr.Prepare battery is aimed at providing every customer with primary energy whether indoors or outdoors, enjoying green travel!
2-in-1 Deep Cycle Lithium Battery & DC Power Station: Our PowerMax is an innovative lithium battery that can be used as a standard LiFePO4 battery and a portable DC power station with the dedicated MaxHub.
Versatile Recharging Power Station: Our MaxHub has an Anderson port with built-in MPPT and a USB-C port with max.100W output. Recharge the battery directly using a 100W solar panel or a PD charger. You can also charge the battery with a LiFePO4 battery charger or solar array system. (Note: Solar panel, PD charger and LiFePO4 battery charger are not included.)
Improved BMS Protection: Our upgraded BMS expertly protects the battery from over-charge, over-discharge, over-current, short circuit, high and low temperature, offering exceptional performance and prolonged lifespan. Plus, IP65 waterproof and V0 flame retardant rating ensures reliable functionality.
Series and Parallel Connectivity: Our PowerMax battery supports series and parallel connections, allowing you to create a 12V, 24V, 36V, or 48V battery bank, or 12V 200Ah, 300Ah, or 400Ah power system. You can even connect up to 16 batteries in series and parallel, building a powerful home backup power system with a 20.48 kWh capacity. (Note: Ensure each battery is fully charged individually before connecting in series. Install and use MaxHub after connecting batteries.)
More User-Friendly Designs:With the provided metal brackets and screws, you don’t have to make brackets yourself. Simply secure your battery in your RV or boat to keep it in place. The sinking bolt design allows you to stack your batteries vertically to save space (Note: Not suitable for moving spaces). The handheld strap ensures easier carrying and using anywhere.
