Digital Wireless Backup Camera System Kit, AHD1080P, Wireless Rear View Camera and 7” LCD Wireless Reversing Monitor for Trailer, RV, Bus, Trucks, Horse-Trailer, School Bus, Farm Machine,etc
Price: $159.99
(as of Sep 14, 2024 21:30:17 UTC – Details)
Why choose YUWEI Wireless backup cameras system:
1. Stable & reliable digital wireless backup camera signal.
2. Our Wireless Camera Transmission Distance suitable for RV, TRAILER, 5th WHEEL, MOTORHOME, BUS and so on.
3. The monitor has a built-in wireless receiver module, while the camera has a built-in wireless transmitter module.
You will only need to connect two wires for camera, the system will work!
4. Monitor installation takes one minute, Installing the whole system is less than 1 hour, saving money and saving time. Enjoy the fun of DIY.
5. You will no longer worry about reversing in the next 5 years.
wireless backup camera, reverse camera, rear view camea systemwireless backup camera, reverse camera, rear view camea system
Full HD backup camera 1080P high resolution
Our new and professional Full HD backup camera offers real good picture quality, long and instant signal.
rv backup camerarv backup camera
Split view backup monitorSplit view backup monitor
1 to 4 cameras, so easy1 to 4 cameras, so easy
This wireless back up camera system utilize new technology with instant & long transmitting distance allow you install it to different vehicles you may have, RV, Trailer, Truck, 5th wheels etc.
You don’t need to concern cable running around, and all necessary kits included in the package for you do install system by yourself easily. We stay in touch lifetime:
Split view mode option to select one view if needed
Our AHD wireless camera system enables you to view two cameras with split view mode option & select one view if needed, good for you to plan a observation camera.
Spare camera is available separately when you want to expandable system to four cameras view surrounding your vehicle or in the cabin.
parking Linesparking Lines
rv camera wirelessrv camera wireless
trailer cameratrailer camera
Our high definition wireless monitor features to display parking grid lines, the reference lines could tell you to judge how far left in the rear of your vehicle. This smart parking assistance distance grid lines will provide you a safe guide when reversing. You can still decide to set it to displays on or off on the screen.
Camera Image Flip and Mirror changeable
Every backup camera’s image can be switched flip / mirror modes, this gives your more selection to install camera to different places but get desired image view. Meanwhile the bracket allows to adjust angles meet installation place demand to get correct observe range.
Wide View Angle 120
View angle of 120 would provide you all blind spot area behind you and the HD technology helps you clearly what’s the obstacle.
built-in DVR recordingbuilt-in DVR recording
With robust design and completed waterproof, this digital wireless RV backup camera can works at ultimate weather and environment.
HD wireless backup camera offer has bright LED lights offer super night vision and auto turns on under low light circumstance which ensure you will view clear camera image at all time.
Built-in Video Recording function as dash camera
The good and useful function is with built-in DVR recorder, it can works as dash camera to recording each camera’s image at driving. Long video recording time up to 6 hours for 32G SD card (SD card not included).
This system is Full HD 1080P Digital Wireless Backup Camera, it transits stable camera video signal with no interference, it’s ideal rear view camera system recommend to use is system we recommend to use on vehicles under 60ft, such as: RVs/Trucks/Campers/Trailers and etc.
Wireless monitor supports max four wireless cameras, and displays cameras in optional view modes, full view single camera, split view two cameras, quad view four wireless cameras, this system included one camera, spare camera’s model is YW-AHD0628 or search B094D2KZ39.
Wireless reverse camera has good view angle enable to see almost blind spots when you reversing the vehicle, this helpful for you safety driving. Wireless rear view camera is also with high waterproof grade IP69, suitable to use in different environments. Monitor uses IPS screen, driver can see clear picture of camera video at any angle without reflection or blur, sun-shade cover also helps to avoid direct sunlight on monitor.
Easy to install. Connect camera to reversing/running lights or other constant power source (DC 12V), then connect the monitor to 12-24V cigarette lighter, it is the best choice of backup camera system for RV Trailers, Trucks, Camper, Van, Motorhome, 5th wheel, Tractor, Pickup, Semi Box Truck.
We have been in car electronics for 16years, there are around 500 vehicles install our rear view camera system worldwide countries/areas, we provide professional instructions and reliable customer services; we also provide the technical support and replacement service. If you have any questions, please contact us.
