Price: $29.90 - $19.99
(as of Sep 18, 2024 03:30:14 UTC – Details)
Why choose DEGEN DE13 radio?
1. Cranking Dynamo&Slar Power Supply
2. Red LED Light(Flashes)&Alarm Fuction
3. Flashlight with 3 LED lights
4. Cell Phone,MP3&MP4 Charging Jack(Standard USB port)
5. External Adaptor Jack(MINI USB 5 Pin Jack)
6. Built-in Speaker
7. Earphone Jack(D3.5mm)
8. Power Sources:NI-MH Battery,3 X AAA Alkaline batteries or Solar Power
9. Charged by:Cranking Dynamo,External Adaptor,Computer or Solar Power
Frequency range:
FM: 87~108 MHz
MW: 520~1710 KHz
SW1: 5.80~10.00 MHz
SW2: 11.6~18.2 MHz
Sensitivity:
FM≤5uV MW≤2.5mv/m
SW≤50uV
Signal selection: ≥40dB Max.
Output power: about 100mW
Max. volume Output Current: 120mA
Speaker: D50mm
Earphones: D3.5mm
【Provides multiple power sources】Three power supply methods, rechargeable battery power, AAA (#7) battery power, solar power, four charging methods, crank hand crank power, solar charging, USB charging, computer charging, you can also use DE13 to charge your cell phone, MP3, MP4.
【Multipurpose and durable】The upgraded crank radio comes with a lithium battery, enough to charge your cell phone or USB device for a short call or text message in case of emergency. Plus a 3.5mm headphone jack that allows you to enjoy radio programs without disturbing others. This weather radio comes with a flashlight, which is handy in case of an emergency power outage and allows you to see any signal in the dark.
[Alert Radio] This weather alert radio is specially designed for emergency needs. However, it needs to be powered on and manually tuned to a local weather station to receive alerts. It has standard analog tuned AM/FM/SW weather channels. This is a special device designed to receive emergency alerts for a variety of life-threatening weather events such as cyclones, hurricanes, tsunamis and other weather disasters.
【Portable Radio】This pocket-sized portable emergency radio is surprisingly small and light. It measures 13.3*6.2*4.7CM and weighs 0.256KG (not including batteries). For hiking or trekking purposes, this type of radio is a wise choice. In an emergency, carrying a large unit can be quite difficult because you have to move around.
【Must have for home and outdoor】It has high quality speaker and IC with good reception and can be tuned to FM/WM/SW. It has two easy to control dials: one for mixer and the other for volume control with an antenna for enhanced reception. Good expandability to help you get a better signal anywhere. Package includes. 1*DEGEN DE13 emergency weather radio, 1*rechargeable battery, 1*USB charging cabler, 1*wristband, 1*English manual, and 1*12 months worry-free product service.
