DALLUX Backup Camera Cable 4PIN Video Power Aviation Extension Wire for Vehicle Car Camper Bus Van Truck Motorhome Trailer RV Reverse Rearview Monitor CCTV System Waterproof Shock Proof 10m 32.8ft
Price: $13.59
(as of Sep 14, 2024 10:00:24 UTC – Details)
4 PIN  backup camera extension cable4 PIN  backup camera extension cable
4 PIN extension cable4 PIN extension cable
DALLUX Truck RV Backup Camera Upgraded Double-Shielded 4 PIN Aviation Extension Cable
4 PIN Backup Camera Extension Cable,DALLUX Double-Shielded AC10 10M/33FT Vehicle backup Reverse Rear View Parking Camera 4 PIN Video+Audio+Power Cable
DALLUX Upgrade Dopuble-Shielded 4 PIN Aviation Extension Cable widely used to connect Surveillance CCTV Camera, audio and video signals, support for Heavy Duty Vehicle Bus Campers Van Semi-Truck Box Truck Caravans Motor home Horse Trailer Farm Tractor RV rearview backup camera extension cable and so on.
Feature:
-Male to Female Connection 4PIN Aviation Video Power Audio Wire in one Cable.
-100% shielded, offering superb protection against EMI/RFI interference.
-Used to connect Rearview Camera for Bus Campers Van Semi-Truck Box Truck Caravans Motorhome Horse Trailer Farm Tractor RV CCTV.
-Weatherproof, dust-proof and oil-prooffor outdoor use. Power Input:DC12V-DC36V
-Nickel plated plugs to ensure precisely signals transmitting.
Package content: 1x 4PIN connector aviation Cable(10m,33ft)
4PIN backup camera video cable4PIN backup camera video cable
DALLUX Truck RV Rearview Camera 4 PIN Extension Cable
DALLUX Vehicle backup camera Upgrade Dopuble-Shielded 4 PIN Video+Audio Cable
100% shielded, offering superb protection against EMI/RFI interference. This can make your video image much more clear and stable.
DALLUX Truck RV Reverse Camera 4 PIN Extension Cable
4 PIN aviation extension cable4 PIN aviation extension cable
DALLUX Double-Shielded 4 PIN Extension Cable Diameter
We make the video cable thickness up to 5.0mm, which can protect the cable much better and a longer life.
DALLUX 4 PIN Video+Audio+Power Extension Cable
We make this cable with Video,Audio,Power wire all in one, and it is universal type which can compatible with most of this design 4 PIN connector cable.
DALLUX Shock proof waterproof oil proof 4 PIN Extension cable
This 4 PIN aviation extension cable make with super material which have a good performance on shockproof and oil proof, also it is including a rubber cover on the connector to make sure it can waterproof.
4.7 out of 5 stars
348
4.7 out of 5 stars
348
4.7 out of 5 stars
348
4.7 out of 5 stars
348
$13.59$13.59 $11.39$11.39 $16.99$16.99 $20.69$20.69
Cable Length
10M/33FT 5M/16FT 15M/49.2FT 20M/66FT
Upgrade Pure Copper 5mm Super thicker wire diameter 4pin Shied Cable,longer life under kinds of weather condition.
This 4 Pin Aviation extension cable with a Water Proof Rubber sleeve,stainless steel screw tight fixed for a good shockproof.
Use for Heavy Duty Vehicle Bus Campers Van Semi-Truck Box Truck Caravans Motorhome Horse Trailer Farm Tractor RV backup camera extension cable and surveillance CCTV system,32pcs copper wire covered with special tinfoil wrap up to avoid signal loss.
One cable solution deals with power and video and audio signal transmission. No need additional power cable to connect the reverse backup camera.
Special thick hard wire 100% shield offering super protection against vehicle’s circuit interference and other EMI RFI interference.
