Creative Rocker Lighters,Windproof Green Flame Lighter,Butane Torch Lighter,Luminous Lighter with Transparent Visual Gas Chamber,Great Gifts for Men, BBQ Kitchen Candle Without Gas (Gold,Small)
Price: $15.99
(as of Jul 30, 2024 04:00:15 UTC – Details)
After-sale Service:
If you are unhappy with our product, please feel free to contact us and we will give you a full refund or 100% replacement.
Product description:
Product name: Rocker windproof lighter
Product material: metal body
Weight: 65.7g
Type: Inflatable
Note: Size and weight are measured by hand, please understand that there is a slight error.
Fuel: butane
Refilling Tips?
Step 1: Choose Butane
Choose the right butane is very important for lighters. In general, high purity and high-quality butane can prolong the life of lighters.
In addition, the butane with low purity and poor quality contains too much air, which will cause the lighter to fail or fail to ignite during use.
Step 2: Release Gas
Before refilling a butane torch lighter, it is necessary to drain any remaining fuel from the lighter. Open the flame adjuster to set the flame height adjuster to a minimum and use a small screwdriver or other tool to push the refill valve down to release the gas in the tank. Keep away from your face and clothes while operating.
The positive and negative signs will indicate a larger or smaller flame.
Step 3: Filling & Adjust Flame
Make the lighter is upside down and place the butane fuel nozzle into the filling valve,refill the lighter about 5-10 seconds. The filling time can be increased or decreased according to the actual capacity of the tank.
After filling please wait for two minutes to get reach room temperature before use the lighter.
Please remember to adjust increase the flame before using the lighter.
Note: LIGHTER FUEL NOT INCLUDED, all lighters are empty, so please fill fuel before the actual lighting. It is recommended that each ignition does not exceed 60 seconds.
Creative rocker ignition:This metal lighters build with rocker arm ignition design, push down automatic rebound ignition. Not only increase the ignition rate, but also not hurt your hand.
Cyclic inflatin:It has a universal refill valve and comes in a round flame adjuster on the bottom. Pure copper inflatable hole, sealed without air leakage.This durable refillable lighter uses butane gas as fuel. It can be easily Refilled up using any butane gas canister with a long nozzle.
Transparent fuel tank design:This retro lighter builds visible window oil tank design, you can check the fuel condition anytime by the transparent window and add to it when the fuel use out.Say goodbye to the embarrassment of fuel shortage.
Best gift:This lighter is made of strong and durable zinc alloy material, with exquisite workmanship, strong, precise, and wear-resistant. Whenever you use it, it is the embodiment of your high-end taste.The lighter stylish body design, and comfortable texture. It is a great gift for your loved ones, such as Father’s Day, Birthday Gift, Thanksgiving Day, Valentine’s Day.
