Price: $59.99
(as of Sep 12, 2024 06:15:13 UTC – Details)
SUPPORTED FREQUENCIES:
FDD-LTE: B2/B/B/B/B2/B3/B17/B66
TDD-LTE: B38/B40/B41
UMTS: B2/B4/B5
Do Not Support:CDMA/GSM Sim Card!
SUPPORTED NETWORKS:
LTE/HSUPA/HSDPA/UMTS/EDGE/GPPRS
SUPPORTED NETWORKS: LTE/HSUPA/HSDPA/UMTS/EDGE/GPRS/GSM
Our router mainly supports three carriers, AT&T, T-Mobile, and Verizon. If you can not access the Internet, please try according to the subordinate operation (please make sure that your sim card is activated):
1.Insert the sim card, connect the power and turn on the router.
2.Wait for 2~3 minutes, wait for the router to respond, and observe the indicator light (for details, please refer to the user manual)
3.Use your computer to connect WiFi according to the information on the label on the back of the router.
4.Use the browser to open the webpage “192.168.1.1” and login. (Default username: admin Password: FIRSTNUM)
5.Click Mobile→Click APN (enter the information according to the sim card of the different carriers you are using).
If you still can’t solve your problem, please scan the QR code on the user manual
Product Parameters Band: 802.11b/n/g Speed: LTE CAT4 4G 150Mbps, 2.4GHz 300Mbps Power supply: Charging cable Usage: Install a SIM card / Plug in an Ethernet cable Package Include
FIRSTNUM C1 CAT4 4g LTE SIM card Router * 1RJ45 Ethernet cable * 1Power adapter * 1User manual * 1
Brand Story
Firstnum, founded in 2018, is a brand dedicated to the create and invent new communication and network methods.
We want you to live without the inconvenience and uncertainty of where your next wifi router is coming from.
Our routers not only power your devices, but they also provide the technical experience you want with zero restrictions.
FIRSTNUM C1 4g Router with sim card slot is a product which can work with nano sim card. It is more flexible than traditional routers, and it does not need to work with a modem. Thus, we can use it in different places, such as rural area and area without broadband.
Parental Control
Set up and manage your 4g router in minutes by going to 192.168.1.1. Protect your family and devices with advanced WPA/WPA2 wireless encryption, parental controls, and guest access.
Enterprise Level Dual-Core Chip
Fristnum C1 4g Router is powered by the ASR1803L Dual-Core CPU with Linux system, giving it the performance to handle daily networks.
Works with AT&T and T-Mobile
Firstnum 4G router is designed for US users and can support not only AT&T, T-Mobile.
And if you are verizon user, please contact first before you buy, our router can work with verizon on specific states. We will try our best to help you.
PS:The first time you use the machine needs to start the program and read the data, it takes some time to connect to the network and set up the internet, so please be patient with the guests.
【Portable WIFI】FIRSTNUM C1 internet router can output a WIFI signal by inserting a SIM card Simply. And this router for wireless internet works with Major 4G providers in North America, so you can insert a SIM card from AT&T and T-Mobile to get CAT4 internet which download speeds up to 150Mbps and upload speeds up to 50Mbps, and get all your Wi-Fi devices connected to the network. This 2.4 GHz wifi router is very convenient for you to enjoy WIFI in places where ethernet cable is unavailable, such as your holiday cabins or remote cameras.
【SIM Card Slot】Besides the normal RJ45 LAN port * 1, this home router also has a SIM card slot. After inserting the nano SIM card(SIM Data cards are not included) you can enjoy WIFI with your family and friends. Tips: Before inserting the SIM card into the lte router, ensure the SIM card is activated and confirm your SIM card operator supports hotspot services.
【Used In Multi-Scenarios】Since CPE = Modem + Ethernet Router, so the 4g router with sim card slot has a higher efficiency, our router wifi device can be used in different places and scenarios to provide a portable WiFi and a portable hotspot. Besides homes and offices, this wireless wifi router can also be used as WiFi in your car. For example, we can use it in RVs and trucks. Additionally, C1 4g lte router allows 10 devices to connect simultaneously, making it perfect for vacation travel.
【Easy to Set Up and Manage】This wired router only needs 3 steps to set up which is very easy, and the installation details are shown in the manual. After setting up the wifi router long range, we can manage it by entering 192.168.1.1 to log in to the product background. For your convenience, you can press the WPS button to connect to WIFI quickly.
【Single-Band Router】At home, this network router can also work with an ethernet cable, the WIFI Standard of this portable wifi device is IEEE 802.11b/g/n which a maximum speed is 300Mbps. Once an ethernet cable is plugged in, the 4g router will not use your SIM card’s data unless the ethernet cable does not provide any data. This portable long range router is built-in with two 5g cellular external antennas with MIMO 2*2 system to provide a longer transmission distance and higher quality signal. Excellent for those who do not have fiber and use a sim for the internet. Freely to use at home or in small enterprise
【Warranty】We hope our customers can have a good user experience with our products. Therefore, we offer a 6 months warranty. If you have any technical or usage problems with this home wifi, please get in touch with us and we will try our best to help you solve these problems as soon as possible.The first time you use the machine needs to start the program and read the data, it takes some time to connect to the network and set up the internet, so please be patient with the guests
