COSTWAY Portable Car Refrigerator, 55-Quart Dual-zone Electric Cooler with LCD Display, Shockproof Design, -4°F to 50°F, 12V/24V DC, 100-240V AC, 12 Volt Refrigerator for RV Travel Camping, Black
Price: $238.42
(as of Aug 18, 2024 03:30:27 UTC – Details)
Description
You no longer have to worry about the problem of thirst because of our 55-quart compressor refrigerator. It is very useful in the vehicle, which means you can enjoy iced or chilled drinks freely. Dual zone design allows you to store items reasonably according to your requirements. In addition, our high-quality compressor refrigerator can achieve rapid cooling from -4°F to 50°F in few minutes.
Apart from that, we have carefully designed the shockproof function and battery protection in order to adapt to different situations and provide users with satisfied experience.
Feature
High-configuration compressor for faster cooling
With a capacity of 55-quart for storing 84 bottles of 330ml beverage or 19 bottles of 750ml red wine
Separate dual zone areas, including refrigeration and freezing area
It has MAX (fast cooling) mode and ECO (energy saving) mode
Easy-to-operate display panel for controlling temperature
-4°F to 50°F controllable temperature range
Includes 2 power cords for 12 / 24 V DC and 100V to 240V AC input
3-level battery protection to protect your vehicle battery
Low noise and low energy consumption
Internal lighting bulbs allow you to easily and accurately get food
Handles on both side for convenient transportation
Specification
Material: ABS + PP
Product Dimensions: 13.5” x 27” x 21’’(L X W X H)
Item Weight: 38 lbs
Capacity: 55 Quart
Rated Voltage: AC 100V-240V DC 12V/24V
Rated Power: 40-72W(+20%)
Refrigerant: R134a/60±0.5g
AC Voltage: AC 100-120V (Adapter Included)
Refrigeration Range: -4°F to 50°F
Adapt to climate: T, ST, N, SN
Door Style: Single Door
Interior Light: Yes
Noise: ≤45dB
Package includes: 1 x Compressor Refrigerator, 1 x DC Power Cord, 1 x AC Adapter, 1 x Instruction
️[A Multi-voltage System] This portable car refrigerator operates at 12V/24V DC and 100V~240V AC power source, which allow you to plug in a socket at home or use it with a cigarette lighter on the car. The original package includes 1 DC power cord and 1 AC adapter. You don’t have to reset the temperature when you change the power source because of the memory function.
️[Large Capacity] With a capacity of 55 quarts, the car fridge freezer is able to hold 84 bottles 330ml beer, 60 bottles 550ml water and 19 bottles 750ml wine. What’s more, the electric cooler can keep your food chilled or frozen easily without consuming too much energy. It has MAX and ECO working modes for you to adjust as needed.
️[Convenient Operation with LCD Display] With LCD display screen and digital buttons, you can set your desired temperature (range from -4°F to 50°F) and adjust compressor speed conveniently. Internal LED lights also allow easier and more convenient access in low light conditions. Our car refrigerator handles on both sides allow you to move it to any desired location.
️[Separate Dual-Zone Design] We have carefully designed two separate compartments, including refrigeration and freezing area.(not Dual Temperature Control) Dual zone RV refrigerator allows you to store items reasonably according to your requirements. In addition, the travel car refrigerator easy to control the temperature by display panel.
️[Intelligent Battery Protection] Three different levels of battery protection are available, and they are low, med and high. This 12 volt refrigerator design can meet your different needs and protect your car battery well. When the input voltage reaches the minimum value, the compressor stops working; when the voltage returns to normal, the compressor will rework automatically.
