Price: $299.99 - $199.99
(as of Sep 30, 2024 00:30:19 UTC – Details)
🚲12 Months Warranty🚲 Actbest Model Core-Step Over, Powerful Peak 750W brushless motor, Aluminum frame Electric bicycle for Adults with 36V 13AH Detachable Built-in Aircraft-grade Quality Battery for low-carbon and environmentally friendly Long Ride. Features: 1.Powerful Peak 750W brushless motor with speeds up to 22MPH 2.Range of 30 miles (throttle) / 50 miles (PAS) for extended riding 3.7-speed transmission electric bike. 4.26X2.1 inch tires ebike. 5.Removable 36V 13AH Aircraft-grade Quality Battery, waterproof and shockproof. 36V2A charger with cable. 6.Displays key information such as speed, battery level, and assist level 7.Excellent front and rear disc brake systems 8.Front shock absorption. 9.5-stage pedal assist function e bikes for adults . 10.Safety lights: Headlights, rear brake lights. 11. Adjustable seat cushion, for people of different heights (5’4″-6’5″), Lightweight, sturdy, and durable aluminum alloy frame Supports up to 350 lbs 12. Installation instructions and tools included in the e-bike package
Novel Commuter E-Bike with 3+1 Riding Modes – Powerful Peak 750W brushless motor, speed up to 22MPH, with 7-speed transmission, 26”X2.1 tires and 3 riding modes including manual, pedal-assisted and pure electric, helps you smoothly navigate through various terrains even mild hilly areas, during commuting, traveling, and sightseeing.
36V 13AH Removable Built-in Battery – The UL2849-certificated battery is easy to remove for charging and has a waterproof, shockproof and anti-theft design, which is safer and lasts much longer. The battery only takes 4-6 hours to fully charge, giving you a range of up to 35 miles (throttle)/50 miles (PAS) on a single charge.
Enhanced Riding Experience – The Core electric bike is equipped with an LCD screen that displays key information such as speed, battery level, and assist level, making it easy for you to track your ride, and a USB charging port for convenient use. Our bike also features excellent front and rear disc brake systems that provide all-weather braking performance, dual front suspension with key, front lights and rear Reflective Sheet for a comfortable and safe riding experience.
Easy lnstallation & Warranty – Actbest E-bikes Model Core, is almost 90% assembled and comes with instructions and tools. The product comes with a 12-month warranty. If you have any other questions, please contact us, our professional customer support team will provide you with corresponding solutions.
Adjustable and Durable Step-Over Cityrun Ebike – The height of the comfy seat cushion can be adjusted to fit people of different heights (5’4″-6’5″), and the aluminum alloy body is lightweight, solid and durable, can bear up to 350lbs.
