Price: $49.99 - $39.99
(as of Aug 08, 2024 16:00:21 UTC – Details)
The following tips may help you achieve a better calling experience:
1. Please make sure the microphone headband has been adjusted correctly and close to your mouth.
2. Update your Bluetooth Driver to the latest version. (If you use the headphones on your laptop)
3. Make sure all other Bluetooth devices around have been turned off
4. If it is tested under a noisy environment, please try another quiet room to see if it will be better.
5. Please try to make calls directly from your phone without using any conference apps to see if the issue persists.
Notice:
1. Only allows computer which has Bluetooth function. But you can buy a USB dongle if you have no Bluetooth function.
2. Poor sound quality and Bluetooth connection occur sometimes when hardware and Bluetooth Driver are not updated to the latest version (laptops with some bands ).
If it still can not work, please kindly contact our support at any time
3.The mute button can only used on cellphone, if you want to mute on Skype or other calling software on PC, please set it through software.
Adjustable headband & Comfortable Wearing & 270° Rotatable Microphone & Anti-slip pad
The on ear earmuff is made of protein leather, very soft and breathable, which can reduce much pressure bringing to ears . It has large-size adjustable headband, lining with soft protein leather pading on the top, making it can fit most people and provide comfortable wearing. The boom mic is flexible, you can adjust it close enough to your mouth to pick up your voice more exactly.
Long Battery Life & Fast Charging & Mute Function
COMEXION bluetooth headset equiped with large capacity battery, which can provide 34 hours talking time or 400 hours standby time.Your headset is fully charged within 1.5 hours.You can also easily block the sound in your side by pressing the mute key when needed.(*Note:The mute function might not be compatible with some third-party softwares at PC end )
Connect with 2 deivces
COMEXION Bluetooth headsdset could connect with 2 devices ( Phones, computers and laptops) at the same.
If your computer does not have Bluetooth function, you may order our BH-M100 with dongle or order an USB dongle on amazon.
Bluetooth Pairing and Connection:
1. In off status, long press MFB 5-7 seconds to power it on, the headset will enter pairing mode with LED Blue & Red flash alternately.
2. Search and click to connect ”M100” on your phone Bluetooth lists, the blue light will be solid on and will flash every 10 seconds after connected, now you can play music from phone to headphone.
3. When it’s connected with your phone, you can press MFB / Volume+ / Volume- / Microphone Mute Button on the Bluetooth headset to control the answer/hang up a call and play/pause music, next and previous song, volume up and down, microphone mute.
When it’s used on PC and computer, some of the buttons may not be applicable due to the different models of computer and software.
Connection with Computer if it has Bluetooth function
1, Press the multi function button (MFB) for about 5-7 seconds to turn the bluetooth headset on, the red&blue light will flash alternately, which means it enters into pairing mode.
2, Go to settings on the computer and turn on the Bluetooth setting, search for Bluetooth signals and find “M100” to click it, you will hear “your headset is connected”, which means it’s connected successfully with computer. If the computer needs bluetooth driver, please ask for help from your computer manufacturer.
3, To make sure you can use the headset on your computer, after it’s paired with the computer, please check if the headset is set as default output and input device: Go to settings on your computer and find sound settings, set “M100” as the output and input device.
Connection with Two devices:
1, Press the MFB button for about 5-7 seconds to turn on the bluetooth headset, turn on the Bluetooth function on your first bluetooth device, click “M100” to connect it and it will then paired with the first device.
2, Then turn off the Bluetooth function on the first device and the headset will enter into pairing mode again (the red&blue light will flash alternately.) Then turn on the Bluetooth function on the second device to search and connect “M100”.
3, After it’s paired with the second Bluetooth device. Turn on Bluetooth function on the first device, click to reconnect “M100”on Bluetooth lists. Headset is connected with two devices now.
【Mute Function and Clear Sound】One press to mute, you can easily mute your voice during the call. 【Note】 M100 without Dongle can only mute on cell phones, if you want to mute on Skype or other calling software on PC. Please look at another item BH-M100 with Dongle. COMEXION headset also provides stable and clear sound when you make calls, and you could enjoy music with M100. Our Bluetooth headset is perfect for truck drivers, zooming and online meetings.
【Built in Noise Canceling Microphone】Our wireless headset adopts unique adaptive environmental noise-canceling chipset technology, which can identify various background noises in the monitoring environment. Bluetooth headset with microphone can provide a quieter environment for listeners and improve the quality of communication even on the go.
【Extremely Comfortable To Wear】Our wireless headphones with microphone equipped with comfortable earmuffs and ultra soft protein leather for all-day comfort. 270° rotatable microphone can be used on the right or left side, through the MFB button on the Bluetooth wireless headset, you can easily answer or hang up calls (only useful for phone calls) . 【Note】If you want to answer or hang up calls from Skype, Zoom, or Teams on the PC side, please set it up through the software.
【Easy to Connect and Switching for Two Devices】Our Bluetooth headset adopts the Bluetooth 5.0 technology. Which makes bluetooth connection quickly, efficiently and stably. It can pair with 2 devices at the same time. You can quickly switch to your calling device with one click, so you won’t miss any important calls.
【Long Battery Life & Compatibility】1.5 Hours charging can offer up to 30 hours continuous talking time and 400 hours standby time. So you don’t have to worry about using time. Our Bluetooth headset can pair with most Android and IOS Bluetooth-enabled devices; 【Note】If you want to connect a device that doesn’t have Bluetooth, please look at another item BH-M100 with Dongle.
