Coffee thermos,Coffee bottle,Tea Infuser Bottle,Smart Sports Water Bottle with LED Temperature Display,Double Wall Vacuum Insulated Water Bottle, Stay Hot for 24 Hrs,Cold for 24 Hrs (Black)
Price: $19.99
(as of Aug 11, 2024 06:45:19 UTC – Details)
Anti-scald design—-Touching the lid of the cup lightly to display the current water temperature.
The lid of the thermos cup is an LED display, with a built-in measuring chip, a highly sensitive temperature sensor, the temperature is accurate to ±1℃, the screen will automatically shut down after the temperature is displayed for about 3 seconds, and it is equipped with a large-capacity battery that can be clicked to display 50,000 times.
Normal use for more than 3 years, no need to replace the battery.
Why do we choose 316 medical grade stainless steel?
316 stainless steel is a kind of austenitic stainless steel. Due to the addition of Mo element, its corrosion resistance and high temperature strength are greatly improved, and it can be used under harsh conditions.
1. Insulation effect: because the 316 stainless steel vacuum flask contains nickel, the toughness of stainless steel is better, and the fatigue resistance is much better than that of 304, so that the vacuum time of the vacuum flask is longer, and the thermal insulation effect remains unchanged for several years.
The material of 304 stainless steel is relatively hard, with a little rigidity, and is relatively easy to crack. After a few months of use, the insulation effect of the vacuum flask will be significantly reduced.
2. Heat resistance: The high temperature resistance of 316 stainless steel can reach 1200-1300 degrees, and it can be used under harsh conditions. 304 is only general-purpose stainless steel, and the general high temperature resistance limit is 650℃.
3. Corrosion resistance: Due to the addition of Mo element, 316 stainless steel has suitable corrosion resistance in various organic acids, inorganic acids, alkalis, salts, and seawater, and the corrosion resistance is far better than 304.
316 Stainless Medical Grade Steel—-Insulated Water Bottle greatly outperforms 18/8 food grade stainless steel in anti-oxidation and corrosion resistance, it will never leave a metal taste or rust. Avoid the taste of the liquids to change (like tea, coffee and juice).
Long Time for Holding Temperature —-Featured dual walls, premium coated copper on the exterior of the inner wall. High performance temperature retention, keep liquid hot up to 24 hrs and cold up to 24 hrs.
100% Leak Proof & Easy to Clean—-The BPA-free silicone rubber on each lid ensures no leak, no plastic smell. A cup brush for easy washing. Insulated Water Bottle is perfectly suitable for daily use, running, hiking, camping, etc.
