Cobra ACXT345 Weather-Resistant Walkie Talkies for Adults – Rechargeable, 22 Channels, Long Range 25-Mile Two-Way Radio Set (2-Pack)
Price: $29.98
(as of Jul 18, 2024 08:45:17 UTC – Details)
The Cobra ACXT345 is a rugged, weather-resistant two-way radio/walkie talkie designed for recreational or business use. With up to 25-mile range, Water Resistant (IPX2) Rating, NOAA Weather Alerts, Voice-Activated Transmission (VOX), Channel Scan and more, the ACXT345 is great for clear communication at longer distances.
22 CHANNELS AND 121 PRIVACY CODES – These easy-to-use walkie talkies combine 22 channels and 121 privacy codes to secure your conversations from surrounding hikers, hunters or wherever your adventure takes you.
NOAA WEATHER CHANNELS – Get 24/7 access to NOAA weather channels so you can always be prepared and connected with those you are traveling with in the instance you run into bad weather conditions.
VOICE-ACTIVATED TRANSMISSION (VOX) – Hands-free usage to automatically transmit when you speak so you can keep your arms and hands free. Great when hunting or for construction sites or other working conditions.
CALL TONES – 5 selectable tones to distinguish between different parties as well as a channel scan feature so you can automatically scan channels for incoming transmissions. Communicate clear in working areas like hotel, security, and construction.
