Cigar Lighters Soft Flame Lighter Retro Grinding Wheel Traditional Butane Lighter with Adjustable Flame Dial Vertical Ignition Roller Classic Metal Relief Lighter (Gold)
Price: $16.99
(as of Aug 24, 2024 16:00:33 UTC – Details)
TIPS:
1.Fire would be strong or weak after a new refilling,it’s normal.
2.Some air will remained in the gas tank due to the air pressure after you refilling, that will be resulting in several empty clicks.
3.Due to butane is against of shipping rules,all of our cigar lighters are without any fuel.
【Flame Adjustable & Butane Refillable】The soft flame can be easily adjusted through use screwdriver. Clockwise to weaker flame and anticlockwise to stronger flame. Don’t set the flame too high to avoid hurting yourself. And also this butane lighter can be refilled after run out of use, more environmentally friendly.Please ensure the butane canister has the Long Universal Refill Tip. (NOTE: The lighter does not come filled with butane due to shipping regulations)
【Feel Grandpa’s Style】Another highlight of the refillable lighters is the mechanical brass gear design.Floating sparks burst out from gear and grinding wheel linkage friction.You deserved a retro lighter in modern times.(You may ignite for several times because sometimes insufficient friction between the flint and the grinding wheel)
【Ignition Method & Metal Body Design】This cigarette lighter adopts the side pulley ignition mode, which is safer to use. Different from the traditional key-press ignition method, it not only has a high ignition rate, but also does not hurt your hands. Size of this torch lighter is 2.4*1.5*0.5 inch. You can take it to everywhere no matter put in pocket,bag,luggage or just hold it by hand.Good ideal for hiking and camping, hunting, traveling and other outdoor activities.
【Beautiful Appearance & Brighter Sound】Retro design, relief surface, comfortable hand feeling. Micro diamond diamond pattern, more luxurious and noble. Use high-quality zinc alloy and embossing process, strongly wear-resistant and durable enough for long-lasting use, its weight about 63g, so that it can be easily put in your handbag or pocket and won’t take up too much space.There will be a clear sound “Ding” when you open the lid of the lighter, offers a classic look with a modern twist.
【Cool Idea Gift】This traditional flame lighter has a stylish look and ergonomic grip design. As packaged in a gift box, the lighter is suitable for Father’s Day, Birthday, Anniversary, Christmas, and New Year !
