Cigar Lighter Cutter and Ashtray Set 3 Piece Alloy Double Jet Flame Torch Lighter with Punch Cigar Draw Enhancer Tool Refillable Windproof Butane Lighter Gift for Men (Yellow)
Price: $29.99 - $27.99
(as of Aug 15, 2024 13:15:31 UTC – Details)
【Multi-Purpose Lighter】It is a 3 in 1 cigar lighter, extra sharp cigar tool punch for small ring gauge that provides a clean cut every time. The lighter has a hidden cigar draw enhancer tool punch at the bottom.
【Double Jet Flame】 This torch lighter consist of 2 sturdy turbocharged burners, which produce concentrated and powerful turbo jet torch flame. more firepower than single flame lighters. So you can ignite items faster, jet flames will not extinguish even when there is wind outdoors.| NOTE: Lighter Does Not Contain Gas, Please Refill It First Before Using.
【Refillable & Adjustable】 Unlike disposable lighters, This double jet flame butane lighter is refillable, Longer life and more environmentally friendly. tilt the lighter to see the remaining amount of butane from a small window. Flame adjustment valve is located at the bottom of the lighter, you can adjust at any time.
【Easy to Clean & Durable Ashtray】 Our ashtray is made of stainless steel, its golden ratio can easily support cigars of any size. It is resistant to wear and tear, non-slip bottom. Easy to clean, with a simple rinse or wipe, the ashtray will regain its luster again.
【What You Get】Multi-Purpose torch lighter*1, cigar cutter*1, durable Ashtray*1, exquisite gift box*1.All items are all put in a beautiful gift box, which is perfect choice for a holiday gift, surprise your friend, husband or father.
