Champion Power Equipment 4500-Watt Electric Start Dual Fuel RV Ready Portable Inverter Generator with Quiet Technology
Price: $1,359.00 - $1,049.00
(as of Jul 31, 2024 19:45:21 UTC – Details)
The Champion Power Equipment 200988 4500-Watt Portable Inverter Generator is the perfect combination of versatility and convenience whether you need power for your home, RV or project. The convenient electric start includes a battery, plus Cold Start Technology ensures a quick start in cold weather. Connect your sensitive electronics with confidence since this inverter produces only Clean Power (˂ 3% THD). Designed for safety with a low oil shut-off sensor, this inverter has a 0.6-quart oil capacity (bottle of 10W-30 oil included). Operate your Dual-Fuel generator right out of the box on gasoline or propane, and easily switch fuels with a quick turn of the fuel selector dial. Using gasoline, the 212cc Champion engine produces 4500 starting watts and 3500 running watts, and will run for 14 hours at 25% load. It produces 4500 starting watts and 3150 running watts, and will run for 21 hours at 25% load when using a 20-pound propane tank. Champion’s Inverter Technology includes smart Economy Mode, which can reduce the electrical load, providing quieter operation, extended engine life and better fuel economy. Included are a 120V 30A RV (TT-30R), two 120V 20A household outlets (5-20R), a 12V DC automotive-style outlet with dual USB adapter, plus a propane hose with a built-in regulator. Operates at 61 dBA from 23 feet – about the same noise level as normal conversation. The optional Parallel Kit provides a quick clip-on connection which allows you to increase output by connecting up to two 3000-watt or higher inverters, and includes a standard 50-amp RV outlet with power to start and run two 15,000 BTU RV air conditioners. Fully assembled with foldaway handle for easy storage and built-in handles and never-flat tires for easy transport. Buy this EPA certified and CARB compliant inverter with confidence – Champion Support and our nationwide network of service centers will back up your purchase with a 3-year limited warranty and FREE lifetime technical support.
DUAL FUEL: Operate your 4500-watt portable generator right out of the box on either gasoline or propane, plus the unit holds 0.6-quarts of oil (10W-30 oil included) and has a low oil shut-off sensor.Fuel Gauge : No. Voltmeter : No.
ELECTRIC START: Battery included, plus Quick Touch Panel allows you to access all your controls in one spot
QUIET OPERATION: 61 dBA is perfect for RVs, tailgating, your next project or backup power for your home, featuring 4500 starting watts and 3500 running watts with up to 14 hours run time on gasoline
CLEAN POWER: RV Ready with a 120V 30A RV, plus two 120V 20A household outlets with clean electricity (less than 3% THD) and 12V DC outlet with dual USB adapter
CHAMPION SUPPORT: Includes 3-year limited warranty with FREE lifetime technical support from dedicated experts
