Car Window Breaker, Safety Hammer – Emergency Escape Tool, Window Breaker Seatbelt Cutter, Life Saving Survival Kit With Light Reflective Tape(2-Pack)
Price: $11.99 - $10.99
(as of Sep 10, 2024 02:00:20 UTC – Details)
TTTT
CAR CAR
OMGOMG
ORANGE-4ORANGE-4
ORANGE-5ORANGE-5
ORANGE-6ORANGE-6
CAR EMERGENCY ESCAPE TOOLS: Essential safety tool! This life-saving multifunctional car safety hammer and seatbelt cutter is durable and reliable, allowing you to quickly exit your vehicle in an emergency situation. One end is a seat belt cutter for cutting seatbelt, and the other end is the window breaker tool with two hardened sharp and heavy carbon steel points.
HIGH PERFORMANCE AND DURABLE: Double-tipped solid cone head car glass breaker hammers which are made of high grade carbon steel combined with engineering plastics, This car hammer is very sharp and easy to break out the window for life-saving. so you can easily make a way to escape. The high-quality razor-sharp steel blade effectively slices through seatbelts to open you and your passengers.
ERGONOMIC DESIGN: The anti-skid handle is long enough, about 6.7in, making it easy to control. Only weighing 0. 3lb, it is so light that you can swing it easily. An invaluable addition to your vehicle safety kit, the emergency hammer breaks side window glass with minimal effort, thanks to its solid steel double-sided strike point.Our safety hammer emergency tool combines a protective bracket for the cone head hammer, making it fine from all aspects.
MOUNTING BRACKET INCLUDED: Keep the car hammer stationary and ready to use If needed. Easy to keep it in Glove compartment, door pocket or armrest Box etc. Note: Mounting screws is not included.
CONSIDERATE DESIGN: The window breaker’s removable mounting bracket allows for easy deployment whenever required. Alternatively, you can secure it in place using the provided screws. Effortlessly access your car hammers by storing them in the glove compartment, door pocket, or armrest box.
