Price: $9.99
(as of Sep 11, 2024 10:30:18 UTC – Details)
Some tips
Please read carefully!
Use this electric lighter by Adult Only.Keep away from children.Lighters are NOT Toys.Don’t touch the ARC TIP of electric lighter.It’s hot during using.Use way from face,body,clothing and other flammable materials.Storge this candle lighter in dry enviornment and do not expose to high temperature above 120°F for long time especially in a car.Do NOT use this product in water or other liquids,or it may cause a short circuit.During the ignition,there will be the noise of “zee,zee”,which is high-voltage power generation,it’s low decibels that won’t hurt your ears.Please use with ease.Remember to close the bottom safety switch in time after use to ensure safe use and for power savingIf your candle lighter doesn’t ignite? Check to see if the power is suffcient.if a full charge still does not ignite, please contact our AFTER-SALES service.
Package Includes 1* Electric Lighter 1* Charging Cable 1* Gift Box 1* Instruction
Lighter with Safety Lock
The safety lock ensures that only when you push the lock to the right side can you use the lighter, which perfectly protects children’s accidental opening and avoid fingers from scalding. Designed at the bottom, it’s not easy to be unlocked by kids.
Lighter with Power Display
Don’t know when to charge your candle lighter?4 power indicator lights will show the real-time remaining power of the lighter, reminding you when to charge.Keep your lighter ready with enough power for use at all times
Windproof Design
Do you still worry about the flame being blown out by the strong wind? Don’t worry, the windproof design will protect the electric lighter from being blown out by strong wind.Perfect for both indoor and outdoor use.
Upgrade Ignition Head
ARC pulse is designed on the top, ignition is unlimited and more versatile.Also,the arc part is retractable.The new telescopic technology ensures the arc part sliding synchronously with the safety switch,which makes it safer when using this lighter.
4.3 out of 5 stars
10
4.5 out of 5 stars
608
935
935
784
168
Quantity
1pc 1pc 1pc 2pcs 1pc 2pcs
Item Dimensions
6.3 x 0.59 x 0.59 in 6.97x 0.59 x 0.59 in 7.28x 0.59 x 0.59 in 7.28x 0.59 x 0.59 in 10.23x 0.59 x 0.59 in 10.23x 0.59 x 0.59 in
Item Weight
1.25oz 1.25oz 1.66oz 1.66oz 1.76oz 1.76oz
💗【SAFETY PROTECTION】This is a light and handy stick lighter with safety feature.The candle lighter has overcharge and overheating protection design inside and double switch to ensure safety use.Continuous ignition for 7 seconds, the candle lighter will automatically power off. Remenber to push left the safety switch and make the LED lights turn off after use to save battery power for this electric lighter. This electronic lighter has long neck to keep your hand away from dirty or burn yourself.
⚡【POWERFUL BATTERY】 Our electric lighter is equal to 300+ disposable lighters. Can be charged over 600 times. Please charge and make sure your electric candle lighter 100% full charged when you get it so it can last longer. Charging time is about 1hour and lasts 300+ times(real tested data when you can operate the candle lighter skillfully and ignite within 1 second after full charge)each full charge.With its lightweight, non-slip handle, our arc lighter is a utility lighter you’ll ever need.
✅【WINDPROOF & SPLASH PROOF】This candle lighter plasma is wind and splash proof. It’s a electric USB lighter which is suitable for traveling and outdoor use.You can use the windproof lighter in your own backyard for your BBQ. our electric rechargeable lighter also works great for grills and fire pits.Get one for your next camping.And keep some pieces for your candles.The electric candle lighter is perfect for candles,bbq,grill,gas stoves,campfires,fireworks,fireplace,incense burners etc.
🌏【 ECO FRIENDLY & CONVENIENT】 Stop wasting time and money on the refilling lighter and disposable plastics.No more bad butane smell. This rechargeable grill lighter is your new choice. One time purchase to reuse this electric rechargeable lighter over and over again.It’s windproof and flamess USB rechargeable lighter with a hook.Very suitable for traveling and outdoor use,ESPECIALLY for candles,gas stove,grills.This is a quality metal electric USB lighter.Get your cool candle lighter now.
💯【BUY WITH CONFIDENCE】Perfect as a gift and come with a candle lighter,type c cable and a box.Don’t worry for any issue.Don’t like our bbq lighter?Our arc lighter is not as what you expected?Get a broken one that may be caused during transportation?Contact us at anytime if you have any of these problems, our professional team always stand by,no need to return back the candle lighter if it’s broken and we will give you full refund. We are ready to resolve any issue.
