Candle Lighter, Electric USB Rechargeable Lighter Arc Long Lighter Flameless Lighter with Safe Button for Candle BBQ Grill Fireworks Cooking(Blue & Rose Gold 2Pcs)
Price: $11.99
(as of Aug 10, 2024 06:16:01 UTC – Details)
LYTOWNLYTOWN
LYTOWNLYTOWN
LYTOWNLYTOWN
LYTOWNLYTOWN
LYTOWNLYTOWN
LYTOWN CANDLE Lighter—–Always believe technology makes life easier
Have you burned yourself accidentally by ordinary lighters?
Do you find it is difficult to ignite in bad weather or when you are outside?
Are you worried that your child may light the candle without continuous supervision?
Don’t worry, all your problems will be solved by us now. Here are the 3 reasons for you to choose us
– Our lighters have a long flexible soft head that allows you to maintain a safe distance from the flame
– USB arc lighter, the arc drives the flame, no open flame, will not be blown out
– A safe 3-step switch button, no threat to children.
Specifications
Material: Darual Zinc-alloy + ABS
Weight: 50 g*2
Size: 6.3 x 0.6 x 0.6 inches
Aluminium
TREBLE SAFETY DESIGN – LYTOWN rechargeable electric lighter gives you treble protection, you need to flip the blue indicator switch on the bottom then push up the start switch to ignite the lighter. For the safety of customer, the lighter will automatically shut off after 10 seconds of being ignited. Restart the switch, the igniting spark will be re-ignited
WIND & SPLASH PROOF – The lighter is a perfect long matches tool for lighting in windy weather. It is also moisture proof – the long lighter can be used easily during heavy weather. Perfect for travel camping, hiking, BBQs, candles, cooking, fireplaces, fireworks and so on
USB RECHARGEABLE – The long candle lighter uses a premium lithium ion cell good for over thousands of lights. The bottom LED indicator lets you know when the lighter is in use in light or dark. A convenient safety switch is also built in for increased child safety in the home
ECO FRIENDLY & CONVENIEN -High-grade aluminum & High-tech chips & Elegant ergonomic design ensure that we can use the powerful Electric Lighter handy and safety. We use plasma tech to eliminate the need for this harmful chemical. During the ignition, there will be noise of “ zee,zee”, which is high-voltage power generation, please use with relax
What You Get- 2*LYTOWN candle lighters, 2*USB charging cables, . Lifetime aftersale service aims to provide better products & better solutions for you
